It is currently Sat May 09, 2026 6:19 am
PostPosted: Sat Jul 05, 2003 6:36 am
do I need a new speedo? I replaced the cable that the guy that I bought it from threw in, but the speedo does not register... any help wouod be appreciated...
thanks
Chris :(
65 Coronet, 4 bbl, .060 over, mild cam.
66 Valiant, Black, 3spd, Hyperpak, headers.
works in progress...
PostPosted: Sat Jul 05, 2003 11:42 am
Contributor
It sounds like you have a bad speedometer...probably a stripped gear in the head or a broken shaft. They can be repaired, but you can probably find a working unit for much less than a repair would cost.
PostPosted: Sat Jul 05, 2003 12:46 pm
is it something I could try to fix myself? I am going to do the voltage limiter for the other gauges...
thanks
Chris
