| What size brake shoes on rear of 70 Dart? https://slantsix.org/forum/viewtopic.php?t=60775 |
| Author: | InclinedBlockHead [ Sun Feb 12, 2017 1:31 pm ] |
| Post subject: | What size brake shoes on rear of 70 Dart? |
I have a 1970 Dart with what looks to be the 7 1/4 rear end. The parts dealer says there are two different brake sizes that could be on this car. How do I make sure which it is? Thanks. |
| Author: | slantzilla [ Sun Feb 12, 2017 3:58 pm ] |
Take a wheel off and measure the drum. If it is not a disc brake car it will probably have 9" drums. Disc brake should have 10". |
| Author: | Reed [ Sun Feb 12, 2017 4:43 pm ] |
If you don't have a measuring tool handy, look at the "MAX DIA." number cast into the outer edge of the rear drum. It should be 9 or 10. That is the size of the drums brakes and the size of the shoes you need. |
| Author: | InclinedBlockHead [ Fri Feb 17, 2017 9:45 pm ] |
Thanks everyone. 9-inch brakes they are! |
