It is currently Tue Nov 24, 2026 12:09 pm
PostPosted: Sun Feb 12, 2017 1:31 pm
I have a 1970 Dart with what looks to be the 7 1/4 rear end. The parts dealer says there are two different brake sizes that could be on this car. How do I make sure which it is? Thanks.
PostPosted: Sun Feb 12, 2017 3:58 pm
Take a wheel off and measure the drum. If it is not a disc brake car it will probably have 9" drums. Disc brake should have 10".
PostPosted: Sun Feb 12, 2017 4:43 pm
If you don't have a measuring tool handy, look at the "MAX DIA." number cast into the outer edge of the rear drum. It should be 9 or 10. That is the size of the drums brakes and the size of the shoes you need.
PostPosted: Fri Feb 17, 2017 9:45 pm
Thanks everyone. 9-inch brakes they are!
Users browsing this forum: Amazon [Bot] and 4 guests
