It is currently Sat Nov 21, 2026 7:19 pm
PostPosted: Mon Feb 20, 2017 2:33 pm
Car Model: 1968 Barracuda - Fastback
I've read a few messages here about some use of beehive valve springs (also called conical valve springs); I'm looking for a parts list.
Rob Armstrong, Dan Stern, Doug Dutra, Josh Skinner have all mentioned them, but unfortunately - there's little in the way of details.
Does anyone have anything solid to share for a '68 225?
Thanks in advance everyone - have a super week,
-Chris
'68 Barracuda - taking advice on increasing street torque, power, & road handling. Click To See It
PostPosted: Mon Feb 20, 2017 3:29 pm
Car Model: 62 Valiant
I think you should be able to use small block valve springs. aftermarket units that fit small blocks should be fine along with matching retainers
PostPosted: Mon Feb 20, 2017 3:41 pm
I was under the impression beehive and conical are two different types, with the conical a better solution in most cases.
PostPosted: Mon Feb 20, 2017 4:26 pm
OK - after reading several posts, this is the deepest info I can find. >>> http://www.slantsix.org/forum/viewtopic ... s&start=90 (bottom)
The parts used also included a reduction in valve shaft diameter to 7mm, so the parts list doesn't work perfectly as a bolt-in solution like I'm looing for. It signals that it is possible though!
  • Intake: V4488 from Ranger 2.5
    Exhaust: V4553 from Ranger 2.5
    Springs: VS1648 from Windstar 3.8
    Retainers: YFIZ-6514-CA from Taurus 3.0
    Keepers: Ranger 2.5
PostPosted: Mon Feb 20, 2017 4:29 pm
NEVjr - LS engine springs are close, might actual work. I'm looking for data. Would you know the part #s that would work by chance?
Jcc - perhaps there is a technical difference that I'm not familar with. Sorry if it's causing confusion.
Thanks for checking in and sharing your thoughts guys!
-Chris
PostPosted: Mon Feb 20, 2017 4:47 pm
Call Mike Jeffrey. One of the last heads he did used beehive springs. He should be able to fill you in on what it takes. 308/324-3576
PostPosted: Mon Feb 20, 2017 5:27 pm
Last time I looked at this (in 2009) I came up with this info. Took note but never pursued it.
PostPosted: Mon Feb 20, 2017 5:59 pm
SlantZilla - very much appreciate the tip, I'll certainly give him a ring.
SlantSixDan - here's where you left off "Comp 26995 used in conjunction with Comp LS1 retainer." If this rekindles any thoughts of retainers and valves, I'm listening :)
I'm grateful for all your info; this is an amazing resource!
Best to all,
-Chris
PostPosted: Tue Feb 21, 2017 12:22 am
Right, but that was just me quoting. I never tried those (or any other) parts out.
PostPosted: Tue Feb 21, 2017 2:07 am
Not really sure why you need a beehive for a slant build,usually the realm of higher rpm or higher ratio rockers such as Clevelands or BBC to reduce valve train weights,but don't bother looking at Comp Cams springs,they are outsourced of course. Most people use PAC springs ,including most cam companies . They are good parts and they have a comprehensive selection often based on LS dimensions. I know of many people running them in high rpm CHI or SCM headed Clevelands with great results, those small tool steel retainers are a great weight saving.
PostPosted: Tue Feb 21, 2017 3:19 am
I have those on the head Mike did for me. I may have the part numbers here somewhere. I'll look tonight after work.
Rick
PostPosted: Tue Feb 21, 2017 4:59 am
Dan & Steve - thank you both.
Steve - the intent is indeed to reduce mass as mentioned, but more for an overall decrease in valvetrain weight than actual power/RPM gains - although the inherent RPM boost will be welcome. I'm looking to get a quicker-revving engine which suits my use. I'm likely to weight & balance anything that moves (future questions to the forum). PAC is well known to me; I'm looking for off the shelf parts before seeking a custom fabrication mode. I'm quite interested in their custom springs and titanium retainers & locks. Completely anal approach I know, this is my one vice :)
Rick - Wow, that would be great! Much appreciated.
PostPosted: Tue Feb 21, 2017 12:52 pm
Here are the part numbers from the head that Mike did for me.
Springs----Comp Cam-----#26986
Retainers--Comp Cams----#795
Locks------Comp Cams----#613
Locators---Comp Cams----#4697
Springs set up at 1.710-1.725 gives @ 135# seat presure
Hope that helps.
Rick
PostPosted: Tue Feb 21, 2017 6:08 pm
I know for a 318 or a 360 the valve springs from a GM 3.4 V6 work, and are beehive. Not sure if it works for a slant.
PostPosted: Tue Feb 21, 2017 7:22 pm
Hope that helps.
Rick
Are those used with Chevy valves?
