It is currently Fri Nov 20, 2026 6:18 pm
PostPosted: Fri Feb 10, 2017 12:11 pm
bench, what is the best choice for shifter?? Duster hurst style for bencyh? will I need to heat and bend, or weld??? looking for shifter if anyone has extra
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
 Post subject: shifter
PostPosted: Fri Feb 10, 2017 8:55 pm
The stock shifter used for a duster or dart should clear your bench, 70's style. I had a Feather Duster with a bench and it was a Hurst. Cleared the bench no problem.
PostPosted: Sat Feb 11, 2017 3:34 am
I had the factory 4 speed that came out of a 64-65 Dart GT and it had a Hurst shifter handle that cleared the bench seat in my Valiant,
PostPosted: Sat Feb 11, 2017 5:55 am
reason I ask this is that 62 Lancer is a different animal?? front floorpan wise? than the later A bodies... no floorshifts from factory on the 62,9 ALL 3 ON TREE),, the 60-1 valiants had a very different shifter/setup than later A's I am told...
PostPosted: Sat Feb 11, 2017 6:50 am
I thought some of the toads had a factory floor shift? A 3 speed though.
PostPosted: Sat Feb 11, 2017 8:07 am
this is what I am told. the 60-1 could have 3 speed floor shift, shifted poor, then only 3 on tree for 62. the floor shift in 60-1 was odd ball unit, worked POOR.
I will change to A833OD unit behind the slant.
 Post subject: 62 floor
PostPosted: Sun Feb 12, 2017 5:36 pm
the 62 floor is really similar to the vast majority of a bodies. You will need the 4 speed tunnel added to your floorboard.
PostPosted: Mon Feb 13, 2017 6:44 am
Car Model: Road Runner
I'm not sure about the Valiants, but 62 Dodges are B-Bodies.
PostPosted: Mon Feb 13, 2017 7:49 am
the 61-2 Lancer is a Dodge A body, like the 60-2 Valiant.
I have several a body humps, it will have to be fabricated to fit.
funny part is the 62 B body cars are pretty sought after, and have ( to me) the same design bodywise as the Lancer/Valiant. which are NOT sought after!!!
PostPosted: Wed Feb 15, 2017 6:51 pm
I agree with hyper_pak post. I have a 62 toad and 66 2 dr post that was a manual 3 speed that I put a 4 sp in with a bench. No problems with clearances. The transmission tunnels appear to be the same on both models.
PostPosted: Thu Feb 16, 2017 5:35 am
I have scored a hurst shifter box and rods, and from another a M Gasket handle. in th mail! if I need to re work the handle will be ok with me. I hadn't run up on a a body handle but if I find one reasonable ill grab that too. thanks
 Post subject: It's...
PostPosted: Thu Feb 16, 2017 5:40 am
Just to clarify:
1962 Dart is a B-Body
1963+ Dart is an A-body...
PostPosted: Thu Feb 16, 2017 5:33 pm
And a 61 Lancer is very different from a 62 Lancer. The front horns, cowl, floorboards, wiring, etc. Very different.
PostPosted: Fri Feb 17, 2017 6:44 am
I have always had (since mid 80's) at least 2 mopars and usually of the same/similar models. I sold all cars but the 62 Lancer before my move to Tx. back in Nov... I admit I will be lookin for another 61-2 Lancer or 60-2 Valiant for a second project. th good part is they are so cheap but th bad part is their scarcness ha
I do enjoy learning about them, as I have had and learned about all the othr model Mpoars over th last 30 yrs. bad part is I forgot half what I learned!! ha
Users browsing this forum: Bing [Bot] and 11 guests
