It is currently Sun Nov 22, 2026 11:52 pm
PostPosted: Wed Mar 08, 2017 1:36 pm
Car Model: 1966 Plymouth Valiant
Ok, current problem of the day:
Trying to get the power steering working in the outlaw and ran into a touch of a snag. I purchased a Cardone 20-6184 pump and it will not bolt up. The notch in the rear of the reservoir housing is too small and the offset doesn't line up with my bracket. I tried exchanging the new pump into the old reservoir housing and found that the physical diameter and dimensions of the 6184 are larger and will not fit.
Looking online I found a match to a Cardone 20-6129, but no one has it in stock. I phoned Cardone and they said it was an obsolete part and had been discontinued. They did not even have the capability or a kit to rebuild it.
Does anyone have or know a solution to this? Possible rebuild kits or compatible part numbers?
PostPosted: Thu Mar 09, 2017 11:13 am
Contact Steer and Gear,, they rebuild and repair vintage steering boxes, I would not be surprised to find that also rebuild vintage pumps,,
PostPosted: Thu Mar 09, 2017 12:49 pm
You're fortunate to have had this problem; Cardone's stuff is junk.
PostPosted: Fri Mar 10, 2017 5:25 am
How about a seal kit from rock auto?
PostPosted: Fri Mar 10, 2017 6:04 pm
Car Model: 75valiant custom
when i had a similar problem (a split in the housing), i was delighted to see that my power steering pump was a trusty ol' saginaw. i found a junked chevrolet (always in abundant supply!) :wink: and it worked perfectly. the hei and the power steering pump are two of the best parts gm ever made.
note: you must change ALL of the internal parts over from your old unit, or you won't be happy with it. it must have the correct pressure. your original does. i hope you still have it to use. it's actually an easy fix.
