| LBP and SBP https://slantsix.org/forum/viewtopic.php?t=60955 |
| Author: | JohnnyDees [ Sat Apr 01, 2017 1:45 pm ] |
| Post subject: | LBP and SBP |
Can I run big pattern on rear and have small bolt pattern on front? |
| Author: | Reed [ Sat Apr 01, 2017 1:57 pm ] |
Sure. You will just have to carry two spares -- one for each bolt pattern. You might also look into wheel bolt pattern adapters for the front and run LBP front and back. |
| Author: | sandy in BC [ Sat Apr 01, 2017 4:11 pm ] |
Its pretty easy to change the front. The larger pattern give many more options. |
| Author: | JohnnyDees [ Sat Apr 01, 2017 6:14 pm ] |
I will do the front at some point, I found a 7 1/4 with posi that Im thinking of buying and it has BBP. |
| Author: | SpaceFrank [ Fri Apr 28, 2017 1:36 pm ] |
That gives you a good excuse to do a front disc brake upgrade in the future. Most people looking at that swap have to consider the opposite problem (LBP in front, SBP in back). |
