It is currently Sun Jun 07, 2026 11:33 pm
 Post subject: Delaminated damper
PostPosted: Sun Apr 09, 2017 2:53 pm
What to do with a delaminated harmonic damper? The outer ring on mine came off completely today. No worries, I have a known good one to slap on the engine. But is there any way to fix one? I don't want to chuck it in the trash - slant parts are becoming increasingly rare by the day. I figure someone could use it some day, maybe even me.
 Post subject: Re: Delaminated damper
PostPosted: Sun Apr 09, 2017 3:19 pm
Replace it.
Send it to Damper Doctor or Damper Dudes, but...
Naw. The Pioneer damper (or the ATP, or the Dayco PowerBond, or the Dorman) is a couple of mouseclicks away; any of them will work fine on your engine. Most of them are good quality Australian parts. Re-use the original front (power steer) and/or rear (air condition) bolt-on auxiliary pulleys as needed. Or if you'd rather have a factory Dodge truck heavy-duty 3-groove damper, I have one left on the shelf, new in box; send me a PM.
PostPosted: Sun Apr 09, 2017 3:35 pm
Thanks, Dan. I'll squirrel this away in the parts lager and someday send it to damper dudes. I didn't know if they were readily available, but looks like they aren't as rare as I thought.
