| Crank hub issues https://slantsix.org/forum/viewtopic.php?t=60988 |
| Author: | Magnumforce1987 [ Sun Apr 09, 2017 8:41 pm ] |
| Post subject: | Crank hub issues |
Hey guys, got an issue and I hope it's an easy fix. I got this slant 6 with a crank flange I.D. of 1.55" and my torque converter nose pilot hub is 1.88" can I hone to fit or am I hosed? |
| Author: | DusterIdiot [ Sun Apr 09, 2017 9:20 pm ] |
| Post subject: | Yep... |
Yes you can hone to fit, it will leave the ring on the crank flange a bit skinny, but you're worried about torque convertor, not a flywheel.... make sure your flex plate matches too... |
| Author: | Magnumforce1987 [ Sun Apr 09, 2017 9:46 pm ] |
My father has a honing kit, is it something that can be accomplished at home or strictly machine shop? |
| Author: | Dart270 [ Mon Apr 10, 2017 5:46 am ] |
Strictly machine shop. Way too much material to hone away. You need a crankshaft lathe and cutting tools... Lou |
| Author: | Magnumforce1987 [ Mon Apr 10, 2017 6:22 am ] |
Damn, that sucks. Engine is already in and all. |
| Author: | Charrlie_S [ Mon Apr 10, 2017 12:33 pm ] |
| Post subject: | Re: Crank hub issues |
Quote: Hey guys, got an issue and I hope it's an easy fix. I got this slant 6 with a crank flange I.D. of 1.55" and my torque converter nose pilot hub is 1.88" can I hone to fit or am I hosed?
If it is not a special stall speed converter, you can get a "conversion" conveter from dacco. call (800) 443-2226 For a 67 older engine and 68 newer trans part number 762S For a 68 newer engine and trans part number 762 For a 68 newer engine and 67 older trans part number 762X I think if you call them, it is possible to special order a limited higher stall speed over stock. |
| Author: | Old6rodder [ Mon Apr 10, 2017 3:18 pm ] |
You can have a nosed ("Forstner" concept, but for metal) cutter made that'd do it (carefully) in place, but you'd still need a later flex plate. The "adapter" T/C mentioned'd likely be cheaper and easier all the way around. |
| Author: | Killer6 [ Mon Apr 10, 2017 8:32 pm ] |
The engine isn't in "& all" because it isn't even bolted up to the trans yet. Look, You've got two choices, pull the engine & replace it or the crank in it, or pull the crank & have the hub register turned oversize. The problem here is the subject vehicle is a truck, and just as on FABO, You have not specified whether or not the tranny is A904/998/999 based, lock-up or non-lock-up, or A727 based. If, and only if, it is the A904 series & non-lock-up the hybrid converter is available as Charrlie_S has advised. But it is not available in the types generally wanted for performance. Some of us are familiar w/Your vehicle, but posting open questions w/o providing details leads down all sorts of misleading & fruitless paths, help Us help You Dude, 'ts all I'm sayin' Peace......... |
| Author: | Charrlie_S [ Tue Apr 11, 2017 3:26 am ] |
That is correct. My error, in assumming it is a non lockup 904 trans.
lock-up or non-lock-up, or A727 based. If, and only if, it is the A904 series & non-lock-up the hybrid converter is available as Charrlie_S has advised. . |
