pre-67 transmission and crank
https://slantsix.org/forum/viewtopic.php?t=6099
Author:  Slantosis [ Wed Jun 25, 2003 7:12 pm ]
Post subject:  pre-67 transmission and crank
I'm confused about the compatibility of a pre/post 67 slant transmissions, with a 66 225. The slant that I'm building is a 66 block with a 66 crank so I would need to use a 66 or older tranny right? What is the reason for this?
Author:  v8440 [ Wed Jun 25, 2003 8:54 pm ]
I think you can use the '67 transmission-it's the '68 and newer cranks that had a bigger pilot hole in them for the torque converter hub or pilot bearing.
Author:  slantzilla [ Thu Jun 26, 2003 8:57 pm ]
You can use the early small pilot crank with a late trans if you get a converter made with a small snout on it. :shock:
http://www.slantsix.org/articles/hrm-sl ... ov-pg2.jpg
