It is currently Thu Jan 01, 2026 7:19 am
 Post subject: non resistor spark plugs
PostPosted: Wed Apr 19, 2017 3:36 am
No radio involved/ radio delete car. any advantage/disadvantage to running these plugs...non resistor types????
guidelines for cars still running points/hei/pertronix etc....thanks...
I was thinking of trying some autolite ar51's in my slant. I am using a pertronix ignition.
PostPosted: Wed Apr 19, 2017 5:33 am
Why? What head type (peanut or tube) and what perf/buildup level and desired driving conditions?
PostPosted: Wed Apr 19, 2017 8:34 am
No advantage -- only disadvantages, even if you don't have a radio.
Today's Autolite = Chinese-made junk. Use NGK ZFR5N (stock number 3459) gapped to 0.040". If your head is a '63-'74 item, remove the metal ring washer from each spark plug before you install it.
