It is currently Mon Jun 01, 2026 12:31 am
PostPosted: Tue Mar 28, 2017 12:53 pm
Curious how long your remflex manifold gaskets survive? I have about 15k on my rebuilt motor, the 2 manifolds were both Blanchard ground together, and I noticed for a while I developed an intake leak especially on #3-4 runners and possibly a couple more. I remember torquing manifold to the reccomended specs. Don't know remember the lb# but remembering it being quite low. I've torqued it a bit more up to 15 lbs now with no fix.
I'm going to need to replace gasket. A bit bummed to get less then 15k out of a fancy gasket
PostPosted: Tue Mar 28, 2017 3:55 pm
It should last much longer than that. I'm going on 8 years with mine.
PostPosted: Tue Mar 28, 2017 6:10 pm
I'm at about 3 1/2 years. Not the slightest leak. What kind of intake? (Stock, Aluminum, aftermarket?)
1964 Dart GT
PostPosted: Tue Mar 28, 2017 8:11 pm
Are there any exhaust leaks as well?
Also, were the manifolds separated after grinding and put back together? 3-4 are joined together... for those to leak after being ground together, the entire intake may be moved back from the exhaust.
Any studs leaking coolant? Remflex don't like any liquid on them.
PostPosted: Tue Mar 28, 2017 9:09 pm
Stock manifolds. Both were lightly snugged up to head, then torqued together with 3 bolts with a remflex gasket. Then Blanchard ground, then installed on head. Manifolds have never been off the car. No exhaust leaks i can tell, and no coolant leaks
PostPosted: Tue Mar 28, 2017 10:12 pm
All sounds good there then... something else is amiss. Some have even gotten away with re-using the remflex if the manifolds come off clean.
Any chance the intake has cracked? Or one of those porous e-beam welded units?
PostPosted: Fri Apr 07, 2017 8:30 am
This thread is timely for me so hope you dont mind me chiming in and asking questions in the same topic....
We tried using a green reusable gasket but have leaks so we are switching to a Remflex....
We used a brand new Dorman exhaust manifold and a used 2 bbl manifold we picked up local and the green gasket. When we did our test fit with the engine out, we assembled them to the head first and then tightened up the manifold to manifold bolts.....then removed as a unit from the engine for reinstall, then reinstalled the unit once engine was in the car......still had leaks.....
We had checked the surfaces of the manifolds prior to installing and they seemed flush etc.
Should we plan on having the manifolds planed anyways ? From all the talk I heard about the Remflex gaskets, the manifolds would have to be WAY out to have leaks....
Was hoping to have this be a one day job but dont want to have to do it a third time.
Also -- what studs in the head are actually into water jackets? I was thinking for some reason they were all "dry"......??
PostPosted: Fri Apr 07, 2017 9:15 am
All or most.
The casting is open water Jacket behind the Manifold / Port Face
PostPosted: Fri Apr 07, 2017 10:11 am
All or most.
Thanks Greg. Lovely..one more thing to worry about... :roll:
Hey do you know of any shops around our area that would take a walk-in "hey can you plane my manifolds for me real quick" request ? :?:
Broughers said they dont have equipment long enough to do it....
PostPosted: Sun Apr 09, 2017 2:16 pm
Any idea how tight I can torque without worrying about cracking a manifold? I doubt it would help at all though. Think I'm at 15 lbs now
PostPosted: Sun Apr 09, 2017 3:43 pm
Overtorque is not the answer. You need less torque with a Remflex gasket (5 lb·ft), not more. Torquing it tighter and tighter is a 'death spiral'.
PostPosted: Sun Apr 09, 2017 6:15 pm
Yup that's what I figured thanks
PostPosted: Sun Apr 09, 2017 6:31 pm
All or most.
No not exactly.
You might try savani machine on versalies avenue in mckeesport.. across from unimart.
The machine /raceshop is around back on the bottom level
They know their stuff and its not a wasted trip as it should be close for you.
PostPosted: Sun Apr 09, 2017 11:27 pm
There is no seemed... either it is or it isn't. You need to put them against a straightedge and use feeler gauges or hold light up to it and look for any escaping.
Yes some gaskets may take out of whack manifolds better then others, but ultimately it's a crapshoot and delaying the inevitable.
PostPosted: Mon Apr 10, 2017 5:14 am
Since there is so little torque for the remflex (5-7 ft lbs) - , Dan, do you recommend a thread sealer for the nuts?
And the package says that 1/16" gaps are no problem....truth?
Any sort of sealer additional to the remflex recommended?
