| non resistor spark plugs https://slantsix.org/forum/viewtopic.php?t=61037 |
| Author: | Valleyant [ Wed Apr 19, 2017 3:36 am ] |
| Post subject: | non resistor spark plugs |
No radio involved/ radio delete car. any advantage/disadvantage to running these plugs...non resistor types???? guidelines for cars still running points/hei/pertronix etc....thanks... I was thinking of trying some autolite ar51's in my slant. I am using a pertronix ignition. |
| Author: | Dart270 [ Wed Apr 19, 2017 5:33 am ] |
Why? What head type (peanut or tube) and what perf/buildup level and desired driving conditions? Lou |
| Author: | SlantSixDan [ Wed Apr 19, 2017 8:34 am ] |
| Post subject: | Re: non resistor spark plugs |
Quote: No radio involved/ radio delete car. any advantage/disadvantage to running these plugs...non resistor types?
No advantage -- only disadvantages, even if you don't have a radio.Quote: I was thinking of trying some autolite ar51's in my slant.
Today's Autolite = Chinese-made junk. Use NGK ZFR5N (stock number 3459) gapped to 0.040". If your head is a '63-'74 item, remove the metal ring washer from each spark plug before you install it.
