It is currently Sun Dec 28, 2025 6:50 pm
 Post subject: What Carb to buy??
PostPosted: Thu Apr 27, 2017 8:20 am
I'm trying to build up my slant with a V-5 G supercharger and I'm not sure which carb to go with or if this build is even possible... thoughts??
http://legacy.vortechsuperchargers.com/ ... p?id=30014
Link for supercharger
PostPosted: Thu Apr 27, 2017 2:13 pm
Anything is possible, but can be really difficult depending on your budget and level of skill... You would want a boost-referenced carb for sure. How much boost and what power level are you after?
PostPosted: Thu Apr 27, 2017 3:08 pm
Budget is around 4 and I'd be willing to push 5 and as for skill I'm a newbie at all this but I have sone professional help as well. I want to push some good power out of it... 450hp? Maybe 5 lbs of boost minimum. This is my first build ever
PostPosted: Thu Apr 27, 2017 7:12 pm
450 HP is a lot more than you think it is. In a Slant 6 Dart (light compared to new cars) that will get you into the 11s. For your first build ever, I would use a Holley 500 2bbl for simplicity of tuning, AND read everything you can about boost-referenced carbs. Shoot for 5-7 psi and 250-300 HP and you will go fast and enjoy it. What is the car and do you have the engine (block and head) built already?
Best wishes,
PostPosted: Fri Apr 28, 2017 7:55 am
I appreciate the help. I'm going to attempt to build up a 86 D150. Once I pull the head I'll get an idea...
Users browsing this forum: Greg Ondayko, kesteb and 2 guests
