For Corners
https://slantsix.org/forum/viewtopic.php?t=61063
Author:  Greg Ondayko [ Thu Apr 27, 2017 11:12 am ]
Post subject:  For Corners
Is this a recommended part for 64 Darts?
https://www.summitracing.com/parts/aco- ... structions
Are there better Options or is this one good?
Author:  SpaceFrank [ Thu Apr 27, 2017 1:18 pm ]
There are better (and more expensive) options, but that's the one I have on my 64' Dart LeMons racer. The only real downsides to it are the crappy mounting brackets. I think Lou is the one I saw in an old thread talking about how to improve the mounting situation.
Author:  sandy in BC [ Thu Apr 27, 2017 1:19 pm ]
That looks the same as the others.
You will need to re engineer the K mounts, ( 2 pieces of angle)
Author:  Greg Ondayko [ Thu Apr 27, 2017 1:51 pm ]
Cool.
I can re engineer things... thats easy.
Yay welding😀😀
I bet i can get this thing Skookum asFrig in no time.
I think lou will chime in as well.
Author:  Dart270 [ Thu Apr 27, 2017 2:21 pm ]
That looks like the same mounting brackets and instructions that Addco had in 1989-1990 when I bought my first one for my 68 Dart, and again in 1998 when I bought the second one for the 64 Dart. Ugh.
If you can spend that, then spend a few extra bucks, save 5-8 lbs (tubular), and get better mounting brackets.
https://www.summitracing.com/parts/hel-55914
I just put one of these (for later Dart) on my 68. I still had to mess with the brackets a bit (weld/shim/adjust), but the hardware was so much better than the Addco stuff.
Author:  Greg Ondayko [ Thu Apr 27, 2017 3:14 pm ]
So... ditch addco. And get hellwig?
I like lighter.
Author:  emsvitil [ Thu Apr 27, 2017 5:27 pm ]
Here's the addco fix:
Addco just uses the bottom bolting (angle iron bolted to K-member,bottom A/R mount to angle iron). The fix is to also bolt at top as shown.
Author:  The Moffittman [ Sat Jun 03, 2017 9:18 am ]
Careful not to let the shmoo out of 'er, wa.
Author:  sandy in BC [ Sat Jun 03, 2017 10:01 am ]
Givver!
Author:  The Moffittman [ Sat Jun 03, 2017 11:24 am ]
Anybody else out there an AvE fan?
Greg, I met you briefly at Mason Dixon. I was the tall guy who mistook you for a dude I was supposed to meet who called his car the "Ruster" also.. Turns out he didn't have it written down the side of his door. I didn't put two and two together until I saw your screen name later that night.
Author:  Greg Ondayko [ Sun Jun 04, 2017 1:31 pm ]
RELEASE THE SCHMOO. and We'll see if it chooches on the gland end.
