Wipers Don't Work
https://slantsix.org/forum/viewtopic.php?t=61082
Author:  63dartdude [ Mon May 01, 2017 11:48 am ]
Post subject:  Wipers Don't Work
All of a sudden my wipers don't work. I see this thing under the dash dancing around when I turn on the wipers. I believe it should be sitting solid, instead of free. Where does it hook up to?
Author:  Killer6 [ Thu May 04, 2017 8:56 pm ]
:shock: :shock: :shock: :shock: :shock:
The rest of the car!!!!!!!!
Or maybe more accurately the rest of itself!!!!
Looks like the housing is off the mounting plate, any screws loose &
visible or on the floor?
Author:  Killer6 [ Thu May 04, 2017 9:03 pm ]
I would also check that oil gauge line closely & be sure it wasn't damaged
or pulled from the gauge some....................
Author:  63dartdude [ Thu May 04, 2017 11:46 pm ]
Oil line is fine. Where is the mounting plate? And what does it look like? Thanks.
Author:  63dartdude [ Fri May 05, 2017 6:24 am ]
Thanks killer6. I took many photos under the dash, and see what you are talking about. So now I know what to do. I appreciate your input.
