| choke pull-off out of adjustment? https://slantsix.org/forum/viewtopic.php?t=61094 |
| Author: | rich006 [ Thu May 04, 2017 10:42 am ] |
| Post subject: | choke pull-off out of adjustment? |
On cold start with the choke set, the engine starts normally, but after a few seconds it begins to bog down. I've found I can fix it by pulling and releasing either the choke rod (temporarily simulating hot manifold) or the choke pull-off linkage (temporarily assisting the vacuum kick). Either way, the choke is forced open a little bit and the idle comes up nicely. What's going on here? There is no binding in the choke valve; it moves freely by hand. I'd suspect the choke pull-off linkage is out of adjustment, but why would a temporary assist result in a lasting change to the choke valve position? |
| Author: | SlantSixDan [ Thu May 04, 2017 11:55 am ] |
Because there is (by design) a great deal of friction, tension, and counter-tension in this system. Squeeze the U-bend in your choke pull-of link slightly, as described here. |
