It is currently Sat May 02, 2026 6:58 am
 Post subject: Cooling
PostPosted: Sun May 14, 2017 7:08 am
Any one have suggestions where I can get a replacement radiator for my a body 65 dart. I can only find v 8. I would like a 3 row electric fan aluminum?
No car info 3/27/2017 Guido
PostPosted: Sun May 14, 2017 8:29 am
Try here http://www.usradiator.com/radiators/dodge.html?cat=785 For yours they make a 19 1/4 or a 22 inch core.
Brian
63 Plymouth Valiant Wagon
PostPosted: Sun May 14, 2017 10:02 am
For the electric fan, some have used one from a Caravan or a Taurus from the junkyard. I got one from a Saturn that has never been used for $40 and flows plenty of air. Just take a tape measure to the boneyard and grab the relays while you are there.
PostPosted: Mon May 15, 2017 5:54 am
I haven't spent much time around '65 Darts, but on '64 Valiants with Slant Sixes space is tight between the water pump and the radiator support. With a two-row aluminum radiator, I've got around 2" for an electric fan. I wound up with an offset pushme-pullyou arrangement of 9" fans.
