| valve cover interchangeability https://slantsix.org/forum/viewtopic.php?t=6113 |
| Author: | crosleykook [ Thu Jun 26, 2003 3:39 pm ] |
| Post subject: | valve cover interchangeability |
Are slant six valve covers interchangeable thru the years? I want to use a clean '62 cover on a later motor, but the later cover seems taller. is this correct? |
| Author: | Doc [ Thu Jun 26, 2003 3:58 pm ] |
1960 -79 all interchange, when the Slant 6 got hydralic lifters, the valve cover got wider. Look-up the valve cover gasket years, you will see two different ones called-out. Note that the breather, PCV and oil filler hole positions all moved around over the years. DD |
