It is currently Tue Nov 24, 2026 12:25 pm
PostPosted: Mon Jul 07, 2003 8:29 pm
Just wanted to thank everyone on this board for being such a good resource.
I just got my car back from the muffler shop and had a chance to dial in the carb. I have to say the car runs really really well. When I got it it had a sick 1 bbl on it.
I could never have done this job without the awesome instruction found on this site. I followed them to the letter and I got it right the first time. No leaks or anything.
For what it is worth here are some things I learned from my experience:
Follow the directions in the articles found on this site closely
Test fit everything and then test fit it again
Be careful to check the exhaust manifold for warpage on all planes
Try to get the whole shooting match from one donor car. I had to piece together everything at it made the whole project take a long time.
A 2 1/4 inch exhaust with a single flowmaster sounds really nice.
I have been grinning all day and finding excuses to drive around. Imagine a volare that is actually fun to drive. The car was a total dog before and now it actually gets out of its own way. Also, the /6 with a flowmaster actually sounds pretty good
Now I am already eying a new cam for a bit more umph.
Burn Rubber
The doc
Dr Wheelie
PostPosted: Mon Jul 07, 2003 10:40 pm
If you really want to have fun, see what rear-end you have and get the gears swapped out for 3.23's or if you have the 4 speed manual (Overdrive)..go for 3.55's to 3.73's...you'll really grin then....
Believe me a hearty cam is happier with more gear too, but a stock motor really can take off with a better ratio...
PostPosted: Tue Jul 08, 2003 1:21 am
Boy, I will second that, d.idiot!! My 74 Dart Sport came with 2.76 cogs. With a pretty much stock 225/auto it was a real dog...During a long lull at my shop during the war in April I rebuilt the whole chassis and swapped in a used set of 3.23 open gears from a Volare in my 7.25" axle. Can you say Whole New Car??!! Power and driveability, as well as fuel economy were dramatically improved. I'ts a bit hard to tell exact m.p.g. as I haven't changed the spedometer pinion in the trans, and I went to a different tire size, but the speedo seems pretty close judjing by my car's speed in traffic and driving known distances/ then watching the odometer and speedo. I now believe getting a 3.23 ratio for auto. trans Slant cars ought to be right after fixing obvious problems or glaring safety issues...you need to get ANY engine in its "power band"speed range and the Slant is no different. I would even go so far as to say that I bet more slant Six cars from the 70's would still be around today being driven, if more of them had had proper gearing, instead of being saddled with "Tall Toad Gears"... my guess is that these sub-3.00 ratios were to help the factory achieve higher m.p.g. numbers for the inaccurate and misleading EPA fuel economy ratings of the period. Lugging and loading up the poor slant with these stiff gears gave many of these cars bad performance,and might have prompted more owners to "get rid" of what otherwise would have been a MUCH better performing vehicle... at least if before/after on my Dart Sport is any indication...anyway, Happy Slanting! Tracy Gallaway
Dare to be Different...
PostPosted: Tue Jul 08, 2003 6:37 am
Yup I can tell that the thing has a sub 3 ratio.
How hard is it to get the rear end set up with some 3.23's?
My roadrunner has 3.55s with a sure grip and those are pretty hairy
I would love a 4 speed too but that is too much effort for now. This is my wifes car and she was not too pleased that it was down for several weeks while I took my time on the super six conversion.
So, all I do is pull the diff and then either get a new ring and pinion set or a used chunk and take the assy to a shop and have them shim it all and set it up, then replace the whole thing back on the car and viola?
What donor rear ends will work? Is the chunk the same for an 8 3/4 as it would be for the rear end in a bone stock, no options 76 volare?
I have thought about doing it all myself but shimming the gears for correct contact pattern seems to be a pretty advanced job.
Advice is appreciated
DW
Dr Wheelie
 Post subject: Count the bolts...
PostPosted: Tue Jul 08, 2003 9:02 am
Your Volare rear end is going to have 9 bolts in the rear cover plate (7 1/4" rear, or a roundish 10 bolt cover ( 8 1/4")...
Either one you can still get ratios for, the 8 1/4" would be better, you can also check your local junkyard for the better 8 1/4" rear for the Volare...some Diplomat Cop cars During the early 80's came with 3.21 sure grip rears and will bolt into place under your car (don't forget the driveshaft from the donor car...)
Otherwise see who the 'reputable' shop is around town and have them swap the gears.
On the mpg issue it depends on driving habit and correct speedo gear, a couple of years back I bought a low miler 74 Duster, the 8 1/4" open 3.21 rear developed a bad driver's side bearing, with the 3 speed manual my hwy mileage was about 19.5mpg. I swapped in a bigger exhaust pipe (had a local shop replicate my Feather Duster pipe), the mpg went up to 20.38, the 8 1/4" had to go so I pulled the rear from my parts Feather Duster and swapped it and the drive line in (2.94, 7 1/4" rear). With that rear the 'feel' was still the same as the 3.21 rear, but my mpg improved to 21.5mpg and my top end was higher (engine didn't sound as busy at 70mph...for an hour). That rear developed a dry bearing, so it came out and now it has a 2.76 rear out of a friend's 74 Dart....mpg remained the same, it's now a real clutch burner, top end is pretty incredible (80mph and the engine is 'idling'....)
PostPosted: Tue Jul 08, 2003 9:52 am
I'm a firm believer in too-tall gearing hurting mileage around town. My first car was an '82 4 door Buick Regal. It had the 3.8 2 bbl turd underhood. The incredible thing was gearing-2.14! That's not a misprint. It really was 2.14. After putting a holley 390 4 bbl and edelbrock performer intake on it, I took it to the local 1/8 mile dragstrip. It ran a best of 11.98 at 61 mph, IN FIRST GEAR. The tach I had installed said it was turning 4500 rpm at that point. I don't know what the top speed of the car was on the highway, as the speedometer only went to 85. I do know this: It would peg the speedometer in 2nd gear and then speed up a good bunch more, and the tach said 3300 rpm at top speed in 3rd gear. Your guess is as good as mine on what that was speed-wise.
Looking back, it was obvious that converter slippage was eating up a bunch of power around town. It would have to-the car probably weighed 3600 lbs with me in it, and with 2.14's in back, it would sort of shuffle off from a standstill at full throttle. The highway was a different matter though...
