| 15x8 inch rims https://slantsix.org/forum/viewtopic.php?t=6120 |
| Author: | DART68 [ Fri Jun 27, 2003 9:13 am ] |
| Post subject: | 15x8 inch rims |
Will 15x8 inch rims work on a 68 Dart or should I stick with the 15x7 inch rims? Thanks |
| Author: | mighty mouse 63 [ Fri Jun 27, 2003 3:25 pm ] |
Dart 68: what do you plan to do with the 14s you have now? Dave. |
| Author: | 225dart [ Fri Jun 27, 2003 7:36 pm ] |
id say yes, but the back spacing will be real important, and the tires cant have a big sidewall measurement either. measure measure measure. --chad |
| Author: | Slant Cecil [ Sat Jun 28, 2003 4:34 am ] |
Ballpark backspace (BS) #s needed for 8" wheels. Redrilled stock or aftermarket axles using stock A body brakes, 4"BS. Aftermarket using 10"x2", 10"x2 1/2" or 11"x 1/2" brakes, 4 1/4"BS. This BS will tuck the tire under the car the most and should clear the spring. If you run a large tire, ie 275x60-15, the sidewall may touch the leaf spring, just use 1/8" or 1/4" wheelspacers to move it out. Cecil |
