It is currently Mon Nov 23, 2026 9:55 pm
PostPosted: Mon Jun 19, 2017 3:26 am
I am SLOWLY changing from 9" drums to KH 4 piston discs. The flex line that came with the discs does not fit through the the tab on the sub frame. The hole in the tab is flat on one side and the original drum flex line has a corresponding flat spot.
Are the KH 4 piston flex lines supposed to have the same flat spot, or do i grind the hole round?
If I was half as smart as I thought I was 30 years ago, I'd be twice as smart as I am now
 Post subject: They should...
PostPosted: Mon Jun 19, 2017 4:44 pm
They should have that 'rounded' section... that has been the same mounting style on most mopar cars through the 70's....
