Timing sets; double roller vs. Matched
https://slantsix.org/forum/viewtopic.php?t=61213
Page 1 of 1
Author:  oldnslo [ Fri Jun 02, 2017 6:17 pm ]
Post subject:  Timing sets; double roller vs. Matched
What benefits, if any, does a true double roller timing set have over standard or matched?
Author:  CNC-Dude [ Sat Jun 03, 2017 11:51 am ]
A "true roller" has rollers that are made from solid round material, where as a non-"true roller" has the roller rolled into a circle and has a visible seam, and under extreme loading can fail easier because it isn't a solid piece.
Author:  oldnslo [ Sat Jun 03, 2017 12:06 pm ]
So no benefit in lower rpm applications ?
Author:  sandy in BC [ Sat Jun 03, 2017 12:25 pm ]
Just about the hardest thing on timing gear is a rough idle .
Author:  coconuteater64 [ Sat Jun 03, 2017 1:03 pm ]
My rule of thumb has always been get the best timing set you can afford and you'll likely never have to replace it. Best does not mean most expensive. Personally I don't care if the chain or valvetrain make a little noise if it means I'll never have it fail. I do not ever like using those nylon gears because they come apart and the pieces get sucked into places that cause further problems. I prefer the double roller type.
Author:  oldnslo [ Sun Jun 04, 2017 4:55 pm ]
Thanks for the input
