| 1966 Valiant won't start https://slantsix.org/forum/viewtopic.php?t=6124 |
| Author: | Guest [ Fri Jun 27, 2003 8:09 pm ] |
| Post subject: | 1966 Valiant won't start |
Help! It all started when I replaced the fuel pump; the old one was leaking out the bottom. Since replacing the fuel pump, I have not been able to start the car. I have verified that the pump is pumping fuel (removed fuel line at base of carburetor and pumped fuel into a container while cranking). I can also see fuel spray in the carb while operating throttle by hand. I checked the spark by holding plug wires and/or coil wire to block while cranking, and it looked weak (orange-yellow colored spark). So far, I have replaced the coil (but not the external resistor?), the ballast resistor, and the points and condensor. Verified the distributor is turning. Points set to 0.020. Fusible link seems to be OK (what's the best way to check it?), and ammeter bounces toward discharge while cranking. I'm out of ideas at this point. Any directions would be appreciated. |
| Author: | Matt Cramer [ Sat Jun 28, 2003 6:27 am ] |
| Post subject: | Starting fluid |
Have you tried spraying starting fluid down the carb? |
| Author: | Slant Cecil [ Sat Jun 28, 2003 9:02 am ] |
The external resistor on the coil is for the radio. Set points to .017, .020 advances timing. If you had dist out while installing points, it may not be reinstalled to correct timing. Cecil |
| Author: | lkolo [ Sun Jun 29, 2003 10:08 am ] |
| Post subject: | Re: Starting fluid |
Quote: Have you tried spraying starting fluid down the carb?
Yes, I tried that yesterday per your suggestion. Still wouldn't start. Forgot to mention in my original post, I had also poured a small quantity of gas in the carb, but without success.
