It is currently Wed Jun 03, 2026 9:07 pm
PostPosted: Mon Jun 05, 2017 9:47 pm
The Industrial 225 six in a Hobart G-400 Welder has an aluminum data plate
mounted to a steel plate by the number 1 plug.
From the tag info:
Model Type Serial
H225- 605 E111898
can anyone tell me what year it was built? From the parts characteristics,
I've narrowed it down to 1970 - 1974. Does the first 1 in the serial mean
1971 or is the "E" the date code? Thanks.
[img]https://www.hobartwelders.com/weldtalk/attachment.php?attachmentid=38642&d=1496721961[/img]
PostPosted: Tue Jun 06, 2017 6:50 am
Sounds like a cool find - I'd check the casting numbers on the block as well; decoding these is a bit better documented.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Jun 08, 2017 1:10 pm
Thanks Matt
I found the Mystery Engine Casting Number thread
http://www.slantsix.org/forum/viewtopic ... ing+number
I'll scrape the crud off the manifold side of the block and take a look.
The Hobart Welder site pinpointed the generator assembly date to
April 17, 1971 so it should pre-date that.
Jim
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
