Flex line on disc conversion
https://slantsix.org/forum/viewtopic.php?t=61273
Author:  oldnslo [ Mon Jun 19, 2017 3:26 am ]
Post subject:  Flex line on disc conversion
I am SLOWLY changing from 9" drums to KH 4 piston discs. The flex line that came with the discs does not fit through the the tab on the sub frame. The hole in the tab is flat on one side and the original drum flex line has a corresponding flat spot.
Are the KH 4 piston flex lines supposed to have the same flat spot, or do i grind the hole round?
Author:  DusterIdiot [ Mon Jun 19, 2017 4:44 pm ]
Post subject:  They should...
They should have that 'rounded' section... that has been the same mounting style on most mopar cars through the 70's....
