| Nominal Cylinder Wall Thickness https://slantsix.org/forum/viewtopic.php?t=61282 |
| Author: | Im2old2 [ Wed Jun 21, 2017 4:22 pm ] |
| Post subject: | Nominal Cylinder Wall Thickness |
Would anybody happen to know what the nominal cylinder wall thickness is on a 225? |
| Author: | Joshie225 [ Wed Jun 21, 2017 5:54 pm ] |
Have you read the block article by Doug Dutra? http://www.slantsix.org/articles/dutra- ... blocks.htm |
| Author: | Im2old2 [ Wed Jun 21, 2017 7:02 pm ] |
| Post subject: | Thank you... |
Thank you, Joshua Skinner for the tip on Doug Dutra's article |
| Author: | Joshie225 [ Wed Jun 21, 2017 10:05 pm ] |
You bet. I'll add that some have found the early blocks to have thicker cylinder walls, but I don't have any direct experience there. None of my engine failures had anything to do with block problems, but I've never gone for large overbores either. |
| Author: | Im2old2 [ Thu Jun 22, 2017 9:49 am ] |
| Post subject: | I'm going MAX on everything this time... |
Dutra's article pretty much tells me that the earlier 170 RB is the way to go. I have a great 225 setting here, but I might wind up prowling wrecking yards from here to Walla Walla looking for this 170 engine. I really appreciate your input. I'm finding out after 50+ years of playing with /6's, that I don't know nearly as much as I thought I did. |
