| The good old thin oil https://slantsix.org/forum/viewtopic.php?t=61299 |
| Author: | Mr.6 [ Mon Jun 26, 2017 12:41 am ] |
| Post subject: | The good old thin oil |
My 1986 /6 D100 is by far my favorite scrapping metal truck I ever had. Low to the ground for easy loading . Starts happy ready to take on the day & nice MPG . I like how your in your own world . Roaring around , Shifting . like something is going on till finally you see the police radar sitting & waiting .Then you realize with a smile , oh yeah i'm only going 45 MPH In town the police seem to turn a blind eye to the good old truck as it chugs along at speeds less then all others . This truck is my LIFE, it's there for me ,we make money , this truck is like my security blanket . it's got my back . I'm at about 2500 miles on last oil change . used about 2 qt's so far I checked oil wile cold & noticed oil dripped nicely off oil dip stick My oil used was 10W40 So I figure raw gas diluted oil finally SlantSixDan says oil change intervals can go far based on looking into oil analysis . That being said if oil gets visibly thin , it's time to change . As a note I never see raw black gas smoke from the truck . I kinda use truck as many a work men did . Just use it . I compensate & use 93 fuel next I see I might be changing oil at 2000 to 2500 miles I'd like to fine turn this truck but I'm worried to mess with it. The darn thing RUNS & to compensate with good fuel and more frequent oil change seems a small price to pay for the old money maker . |
| Author: | emsvitil [ Mon Jun 26, 2017 12:44 am ] |
Have you ever changed the fuel pump? If not, it might be leaking into the sump. |
| Author: | BamaFan95 [ Mon Jun 26, 2017 3:34 am ] |
Did you smell the dipstick? If so, did it smell like raw gas? I personally would do an oil analysis and they will be able to confirm if there is a fuel contamination issue, based on flashpoint (the temperature where the oil catches fire). Just my 2 cents worth. |
| Author: | coconuteater64 [ Mon Jun 26, 2017 6:47 am ] |
Quote: Have you ever changed the fuel pump?
Exactly what I was going to say. The diaphragm can become porous over time and allow gas to enter the crankcase.
| Author: | SpaceFrank [ Mon Jun 26, 2017 8:38 am ] |
There are probably other places that do used oil analysis, but this is the most popular one: http://www.blackstone-labs.com/free-test-kits.php You can order a test kit for free, then pay them $28 when you send your sample in. (Looks like they just raised the price from $25.) Just take the sample when you do your next oil change. Small price to pay for peace of mind. |
| Author: | SlantSixDan [ Mon Jun 26, 2017 9:34 am ] |
Premium gasoline is not better fuel than regular. It's a complete waste of money for a truck like yours -- there is no benefit, it just costs more. Black smoke and high oil consumption means your truck is in rough shape. Tuning it up and fixing it will give much better results than writing poetry about how working men use their trucks. |
| Author: | Reed [ Mon Jun 26, 2017 9:48 am ] |
A 1986 truck will have some variant of a lean burn system installed. To eliminate the black smoke, improve economy, and improve performance, I strongly recommend you switch to a non-computer controlled ignition and carburetor. And check the fuel pump diaphragm. |
| Author: | Mr.6 [ Thu Jun 29, 2017 2:20 am ] |
To be clear No Black Smoke or Blue no smell Just the same I will look into fuel pump could just change for the heck oil consumption - some motors use some don't The part time Scrapping for money is a thing in itself , It is a system of finding metal for free Yes a little time and fuel but often when you are going some place any way Like you go to super market and wile to and fro you find $50 & I Do $250 average per week free find not earth shaking , not gonna make a millionaire But to take an old truck and compensate with more oil changes & 93 fuel to eliminate ping Absolutely the money is there the truck earns it as other trucks have also . Scrapping is so powerful an earner I have gone to visit family found local scrap yards and made $300 on a 5 visit just from local toss out refuse using a mini van |
| Author: | Mr.6 [ Thu Jun 29, 2017 2:24 am ] |
Quote: A 1986 truck will have some variant of a lean burn system installed. To eliminate the black smoke, improve economy, and improve performance, I strongly recommend you switch to a non-computer controlled ignition and carburetor. And check the fuel pump diaphragm.
thanksI'm in my late 50's & slant's are a motor I remember , Generally you always knew you had one in front of you . kinda smelly & a droning roaring sound - - I knew the slants for what they were - they were not old back when I was 18 They were slant's |
| Author: | Reed [ Thu Jun 29, 2017 4:26 pm ] |
If you have to run premium to eliminate pinging, something is wrong. Most likely it is a problem with the lean burn system that controls the timing. I suggest your fix the problem causing the pinging rathet than keep using premium. |
