Damn Squeaky Front Disc Brakes!
https://slantsix.org/forum/viewtopic.php?t=61311
Page 1 of 1
Author:  suurthing [ Thu Jun 29, 2017 8:39 am ]
Post subject:  Damn Squeaky Front Disc Brakes!
Hi any causes or issues to check- simple remedys? Front breaks and pads are fairly new...
Thank you for any feedback.
HAPPY MOTORING
Author:  DusterIdiot [ Thu Jun 29, 2017 5:30 pm ]
Post subject:  It could be...
Sometimes using the Disc Brake "Quiet" RTV between the piston and back the pad helps... sometimes the pad material causes it to squeal/'sing' and you have no choice...
If it occurs more when you are in a turn, it can be that the bearings are a little loose allowing the rotor to rub against one pad or the other when it is side loaded.
