| Engine swap https://slantsix.org/forum/viewtopic.php?t=61319 |
| Author: | mopar_nocar [ Thu Jun 29, 2017 7:45 pm ] |
| Post subject: | Engine swap |
So, is there any way to put a slant into a car in place of V8 without swapping k-frame? Working on a 72 Dart here. I might have access to a 69 k frame, but the front end/brakes/torsion bars/bushings/ALIGNMENT are all recently done on the V8 set up. The 318 is a quitter, so that leads to the original question. sb |
| Author: | Reed [ Thu Jun 29, 2017 8:00 pm ] |
If you are careful, you can pull the torsion bars, unbolt the lower control arm, pittman arm, and steering gearbox from the 318 k frame, drop it, and reinstall a slant k frame. Reinstall everything and the alignment should still be pretty close. |
