It is currently Wed Nov 25, 2026 1:06 pm
PostPosted: Tue Jul 15, 2003 12:57 pm
Hi gang,
Almost done with my engine swap. Delayed by a much needed vacation. Is there any trick to getting the engine up off the center link before tightening the motor mount nuts?
Tom
PostPosted: Tue Jul 15, 2003 1:04 pm
Hi gang,
Tom
:shock: :? :?:
Is the engine bolted to the transmission? Does it have the correct oil pan on it? (need more info.)
PostPosted: Tue Jul 15, 2003 1:13 pm
Did you put a \6 from a F-body into an early A-body? If you did the oil pan rests on the centerlink. The only fixes are to dent the oil pan or use a V8 centerlink or use the OEM oil pan.
 Post subject: Answers to Qs
PostPosted: Tue Jul 15, 2003 1:24 pm
Is the engine bolted to the transmission? YES
Does it have the correct oil pan on it? YES
I'm using the oil pan from a /6 225. There is a 1/2" to 3/4" vertical groove where the mounts fit. I just need to get the engine lifted up a little higher before tightening down. FYI: The mounts are brand new.
p.s. The speed of the replies on this web site amazes me. I will make another donation soon.
T.
PostPosted: Tue Jul 15, 2003 1:47 pm
Ok, so which 225 SL6 oil pan are you using??
http://www.dutra.org/pictures/engine/parts/oilpans.jpg
And what chassis is the engine going into? (year and model)
 Post subject: More answers
PostPosted: Wed Jul 16, 2003 2:47 am
I believe it is the blue one (my car is across the river and I don't have access to it at 2:30 a.m.) It goes in a '66 Dart GT. The replacement engine has the same engine ID as the one that was in there- 2806830 RH.
T.
Users browsing this forum: Bing [Bot], BroncoLane and 5 guests
