It is currently Fri Nov 27, 2026 5:35 am
What's the max SCR a Corteco Head Gasket will hold up to?
Poll ended at Thu Aug 03, 2017 4:19 pm
up to 9:1 only 0%  0%  [ 0 ]
up to 10:1 0%  0%  [ 0 ]
up 11:1 0%  0%  [ 0 ]
It'll handle 12:1 0%  0%  [ 0 ]
I could use one instead of O-ringing the block on a blown race 225 0%  0%  [ 0 ]
Total votes: 0
 Post subject: Corteco Head Gaskets...
PostPosted: Thu Jul 13, 2017 4:19 pm
I've never used one, but have one sitting on the shelf from someplace I got it long ago...
What's the highest static compression ratio anyone's used these at?
I have to pull the head off the hpak duster since it's not oiling the rockers or shaft... the engine is 12.18:1 so I would normally go with the Victor Reinz/Mahle gasket since I know they hold up to the pounding...but I have this Corteco gasket on the shelf....
Anyone? Inquiring minds want to know!
PostPosted: Thu Jul 13, 2017 5:11 pm
I had good luck with them, I presume you mean the white ones, but my compression was in the low 11s. They are a bit thicker I think .055 so they reduce compression a bit.
