Some Qs regading engine replacement
https://slantsix.org/forum/viewtopic.php?t=6139
Page 1 of 1
Author:  Spazus [ Sun Jun 29, 2003 10:00 am ]
Post subject:  Some Qs regading engine replacement
Hi Gang,
I'm in the middle of an engine swap (1966 Dart /6 225, auto transmission) and have a series of questions. I've never done this before so I'd like to do it right the first time. It's been quite fun thus far.
Here goes.
1. Gaskets (oil pump, water pump, fuel pump- are all being replaced). Are there any I should use sealer on? If so which ones and what kind of sealer? I think I have the oil pan sealing figured out per the great article from Doug found in the Article section on this site.
2. Fuel pump. I bought a new one to put in. My old one was a Carter and new one is slightly taller (1/2 inch) and does not contain the spring that is found on the Carter. Other than these 2 issues, everything else looks like a direct match. Should I be worried?
3. The replacement head is different from my existing one. To describe the replacement head- it takes small spark plugs and it appears that the plugs are not isolated from the interior of the head (they will get oil on them). This seems odd but I assume that the plug wire boots will cover the opening and keep oil frm blowing out, Correct?
4. The temperature sending unit on my old engine one is on the top of the engine towards the right hand side near the water inlet. I can't tell where the temperature sending unit goes on the replacement engine. Did they change locations over the years? Did they change the design (size) of the units or are they universal?
5. Since I am leaving the automatic transmission in the car, should I attach the lift chain in one or 2 places near the head when removing/installing the engine?
6. Lastly, when putting the engine back in, do I want to use a jack on the back of the engine or the front of the tranny to align them up properly?
Tom
Author:  DusterIdiot [ Sun Jun 29, 2003 12:21 pm ]
Post subject:  To bad I'm not free....
If I had more time, I'd come up and help....
1)apply gaskets and torque to proper specs...
2)Just use new fuel pump and gasket, unless you have a clearance issue, they refined the pump a bit like with all engine components over time...
3)The late style 'BL' has no openings in the head like the drool tube head, the only openings you should have on that side are the plug holes, and the pushrod galleries... So no oil is going to leak out like your thinkin'...
4)Should be in the same location, near the T-stat housing on the front of the head, it'll look like any other bolt hole if it's not installed yet...
5/6)I attach the chain to the two bolt holes in the head (the ones near the manifold set, put a jack under the front of the tranny to adjust the 'angle', and lower the block into place... You'll do some shuffling and massaging to get it all 'right' a friend really helps here...
good luck, you'll feel better when it all falls into place...
Author:  RMDV [ Sun Jun 29, 2003 1:59 pm ]
Post subject:  Re-Item 4;
The temperature sensor is smaller on the later head than on the original one. It should install in about the same place in the head. Good luck with the exchange. Let us know how it turns out.
Author:  Charrlie_S [ Sun Jun 29, 2003 3:24 pm ]
Warning , Warning, Warning. The 66 engine has a small pilot hole in the end of the crank. The 66 trans has a corresponding diameter nub on the torque converter. If you are using a 68 or later engine, for a replacement, the hole in the end of the crank is too large. The cure is to use the flex plate for the later engine, and make or buy an adapter "RING" that fits in the end of the crank and has the same inside diameter as the 66 converter nub.
