Electronic or mechanical?
https://slantsix.org/forum/viewtopic.php?t=6143
Author:  Jopapa [ Sun Jun 29, 2003 3:37 pm ]
Post subject:  Electronic or mechanical?
I want to get an oil pressure gauge into the Dart soon so I can keep better track of the oil than the idiot light will allow me, but I was curious as to which is better, an electronic gauge or a mechanical gauge? I noticed pretty much all the Autometer fluid gauges have that choice...
Author:  Pierre [ Sun Jun 29, 2003 4:12 pm ]
I say keep the stock idiot light as well, just "tee" in the senders with a brass tee availible at your local hardware store. There is something about a big red light staring you in the face...
Author:  Jopapa [ Sun Jun 29, 2003 4:36 pm ]
Good idea. I wasn't originally intending to, but now that I think of it I will go ahead and keep the light. I'm working on designing a custom dash, so perhaps I could rig up an LED idiot light right next to the oil gauge.
So would you say electrical is the best choice, then?
Author:  james longhurst [ Sun Jun 29, 2003 4:36 pm ]
i have never used an electronic gauge in any of my cars, but all the new cars use 'em. sounds like an easier setup. no mess from leaky pressure lines, either.
-james
Author:  Jopapa [ Sun Jun 29, 2003 4:41 pm ]
-james
That's the figuring I was doing, but if a mechanical is more reliable and more accurate, I'd much rather go that route.
Author:  Bob D [ Sun Jun 29, 2003 6:45 pm ]
I wouldn't use a permanently installed mechanical gage without a shut-off valve at the source. Eventually that flexible plastic line WILL break. Leave the valve closed except to periodically check your electronic gage. Thats what I have, and guess what, the last time I opened the valve the plastic line broke. I used it because my stock 30+ year old dash gage tends to have a mind of its own. If you have a good electronic gage I'd skip the mechanical one completely.
Pierre is right. Keep the idiot light as well.
Bob D
Author:  Jopapa [ Sun Jun 29, 2003 7:22 pm ]
Bob D
Sounds like a plan. All the car has is the light, so I'll use an electronic gauge and keep a seperate mechanical gauge for occasional cross-checking.
BTW, what's the optimum oil pressure for a stock /6, and what pressure triggers the light?
Author:  Eric W [ Sun Jun 29, 2003 7:33 pm ]
If your worried about using the nylon line for the guage, use copper line. Personally, I have never had a problem in all the time (20 years) I've used them though. If you go with copper, put a couple of turns in the line, otherwise you will get a ticking sound at the guage. I got a brass "street T" at Tacoma Screw (fastener and tool supply store), with a 3/8 fitting to screw into where the idiot light sender went, and had a place I could put the adapters I used for my oil pressure line. Why have two guages when you only need one that works properly?
Author:  64 Convert [ Mon Jun 30, 2003 12:58 pm ]
Mechanical gauges are wonderful until the first time a line breaks behind a restored dash and covers everything, including the carpet with black oil. Now I take my chances with a electronic gauge.
Author:  Reed [ Mon Jun 30, 2003 11:55 pm ]
I agree with Eric- if you use a mechanical guage think about using copper. More expensive and more time-consuming to install (don't forget the double flaring) but really the best way to go.
I kind of like the idea of an idiot ligt and a guage. Redundacy systems are good, especially when they are as easy to rig up as one of these. This way if you don't or can't look at the oil pressure guage you still get a big red light saying "HEY IDIOT! TURN OFF YOUR CAR!!!"
Personally, I would go with an electronic guage, but that would mean you have to be sure you can find replacement sending units. So maybe a mechanical guage with copper tubig is the better way to go after all...
Reed
Author:  Jopapa [ Sat Jul 12, 2003 11:49 pm ]
Reed
I've got a mechanical gauge on the way, and am using some copper tubing I had sitting around from a ditched water cooling project for my computer (yay for free stuff, kinda). What do you mean by double flaring though?
Author:  bud L. [ Sun Jul 13, 2003 8:51 am ]
Post subject:  ?
I prefer the mech gauge. However, I'd spend the extra $20 and get the stainless steel braided hose to connect the fitting off of the T to the gauge inside the car. It already has the correct fitting for the gauge, and its bullet-proof. If you ever take it to the track, the 'Tech' inspectors have a problem with any other kind of lines run thru the firewall.
I agree, keep the idiot light as well.
