| electronic radiator fan https://slantsix.org/forum/viewtopic.php?t=6146 |
| Author: | Guest [ Sun Jun 29, 2003 10:59 pm ] |
| Post subject: | electronic radiator fan |
I converted to an electronic radiator fan, and so far I like it, was wondering if anyone else has don the same thing and liked it. |
| Author: | Pierre [ Mon Jun 30, 2003 3:08 am ] |
Which fan setup did you use? |
| Author: | Guest [ Mon Jun 30, 2003 2:22 pm ] |
I used a fan from Imperial automotive products that is reversible(can pull air or push it). It hooks onto your radiator with clips, the only thing that I really worry about. (I'll see, the test of time is the best test). I used it as a puller because without refabricating some of my grill mounting brackets I couldn't make it fit as a pusher. It seems to cool my engine better than my original, and their are marginal benifits in power, though from what I've felt it doesn't seem like you feel the power until you are at highway speeds, though at highway speeds the improvement seems very noticeable. It should save on gas, but that's something I haven't really paid attention to, I mean, I know it couldn't hurt MPG, and even if it didn't help, it's not like I have the money to get a more fuel efficient car, so I never bothered testing that. Either the fan is good because it's meant to also work for some larger engines(I believe up to 4+ liters), which makes cooling much better. The only problem is getting it to fit nicely, mine is sort of off-center so it's not quite at full efficiecy (still better the the mechanical fan). I know they have a couple of sizes. If you have a V-8 they suggest using two smaller fans to cool the engine, though if you have a slant 6 it's probably pretty nifty to have the two fans cooling your engine down, and probably easier to fit, but that's just speculation. Either way, just curious to hear if anyone else has one and if they've had it for a long time, how did it age? |
| Author: | 70valiant [ Mon Jun 30, 2003 6:17 pm ] |
I have done this also. I got my fan from an 80's olds cutless cierra GT. it is 15" but the shroud measures 19"x18". it is controled by an adjustable thermostatic switch I got from National Auto. I also had to replace my radiator with a unit from an aspen so it is wider than my old stock one. It has maintained a very constant temperature over the last few weeks when we were having temps in the mid 90's. my milage is also up from 17 to around 18.4. I have done a lot of cooling system work in the last 6 weeks or so. I have replaced the radiator, heater core, temp gage and sending unit, thermostat(went from 195 to a 180), and the fan. ![]() as you can see my fan is also off center. there is less than 5" not covered by the fan shroud and it hangs over almost 2" on the passenger side. so about 17"x18" of the 22"x18" radiator is used under the fan shroud. I really wanted the one off of the Fiero I think I may have been able to center it but I could not get to the bottom bolts. It is sitting on the ground with no front wheels. |
| Author: | Guest [ Mon Jun 30, 2003 9:59 pm ] |
Your setup looks good. I'm debating the thermostat control thing though. I currently have mine set up to turn on as soon as the car turns on, I also have a switch to shut it off if it's cold outside. Glad I'm not the only one who could get it centered, you'd figure that with such a large engine bay you could get a radiator fan in, but no, it somehow has to be tight in the engine |
| Author: | Pierre [ Mon Jun 30, 2003 10:33 pm ] |
I kind of like having the fan there, if I need to turn the crank slightly like when adjusting valves I push down on the fanbelt a bit to make some tension and move the fan with my other hand. Thats how I realized my engine had seized when I pulled over on the freeway after hearing a horrid noise and the car began shaking like no tomorrow |
| Author: | Al T [ Tue Jul 01, 2003 7:44 am ] |
| Post subject: | Big Red's got an electric fan |
I originally kept a modified factory setup but when I installed the hi capacity rad, I switched to a shrouded puller fan. I also rigged up a 2 speed circuit using mid 80's GM parts and its fused directly into the battery - if the engines hot it runs. This is part of my plan to reduce underhood temps. |
| Author: | Jopapa [ Tue Jul 01, 2003 3:24 pm ] |
| Post subject: | Re: Big Red's got an electric fan |
Quote: I originally kept a modified factory setup but when I installed the hi capacity rad, I switched to a shrouded puller fan. I also rigged up a 2 speed circuit using mid 80's GM parts and its fused directly into the battery - if the engines hot it runs. This is part of my plan to reduce underhood temps.
What parts did you use? I've also hear that using a Ford Taurus 3-wire fan will work, but I haven't compared measurements or power consumption for it.I would also assume that using an electric fan would mean needing a higher output GM alt. Am I right? |
| Author: | Guest [ Tue Jul 01, 2003 5:17 pm ] |
I didn't use a bigger alt, seems to work well with no charging problems |
| Author: | Bruce Johnson [ Tue Jul 01, 2003 8:36 pm ] |
I installed a fan I got at the auto parts store $ 79 .. put it in front of the rad. by it self it was not enough for awhile I kicked my self for not spending more $ and got the dual 14" unit. Then I went to the Flea market one day and spoted a dual 14" under a table I asked the girl how much it was and she said "my boyfreind wanted $8 for it, but he would go $5 I'm sure" All she could tell me about it was it came out of a 1990 toyota. the fans are one low profile and one higher the low one clears the waterpump and the shroud matches the width of the radiator so I could screw it in to place they are now hooked up with a thermistat that uses the tube you tie to the radiator, but I wished I had gotten an electric temp guage that has a output to fan relay I think it would be more accurate and run less. happy hunting! Bruce J. |
| Author: | Reed [ Tue Jul 01, 2003 11:09 pm ] |
If you haven't already seen this, it might be helpful: http://ramchargercentral.com/howto/Electric_Fan.shtml Reed |
| Author: | 70valiant [ Wed Jul 02, 2003 5:26 am ] |
There is no way I could ever turn my engine with the fan I use a ratchet on the small bolts on the crank pulley, when it is hot that is even difficult. |
| Author: | Al T [ Wed Jul 02, 2003 10:46 am ] |
| Post subject: | GM parts |
Jopapa . . . I used the relays and the resistor which when in series with the fan motor creates the slow speed. Fan motor amp draw at high speed is between 8 and 10 amps so my current charging system handles it just fine. I also have "500 watts" worth of audo/amps which is a much more serious current draw but so far, I believe my alternator is handling it just fine. |
| Author: | Guest [ Wed Jul 02, 2003 8:18 pm ] |
resistors, I didn't think I needed that, not sure if I do. I currently only have a fuse, the motor runs at 25 amps. Is their something I should know, and if thier is, how should I install it? Of course, should I worry since my alt seems to handle it well? |
| Author: | GunPilot [ Thu Jul 03, 2003 4:02 pm ] |
Quote: If you haven't already seen this, it might be helpful:
Hey, that's a good-looking how-to. Guy that wrote that must be pretty sharp. http://ramchargercentral.com/howto/Electric_Fan.shtml Reed |
