It is currently Wed Jun 03, 2026 2:51 am
 Post subject: Starter Install
PostPosted: Sun Nov 19, 2017 8:18 pm
I rebuilt a 225 slant 6; it's still on the stand. I want to be able to start it before putting it in the vehicle. (I will move it to an actual test stand with engine mounts.)
However, the starter mounts to the transmission. How can I turn it over without the transmission attached?
Thanks
 Post subject: Re: Starter Install
PostPosted: Sun Nov 19, 2017 8:51 pm
Install a flywheel and a bellhousing.
PostPosted: Mon Nov 20, 2017 12:07 pm
Thanks. I actually saw a Youtube today (after my post) of someone doing that. I'll need to see if the bell housing of the trans I have will separate from the trans.
PostPosted: Tue Nov 21, 2017 1:42 pm
Site Admin
As far as I know, you will need the parts from a manual trans setup. That is the way I have always done it.
Chuck Rivers, Webmaster
Image Image Image Image
PostPosted: Tue Nov 21, 2017 5:03 pm
Yep, for mopars...
F*rd on the other hand.... :roll:
Bellhousings aren't too hard to find... slant six 122 tooth flywheels aren't as common anymore...
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 1 guest
