Not enough fuel
https://slantsix.org/forum/viewtopic.php?t=61501
Author:  Mr.6 [ Sun Aug 13, 2017 8:36 pm ]
Post subject:  Not enough fuel
Ive had symptoms for a wile but I could still use truck
finally the base symptom hit harder and now I can't use truck
For sure it's not plugs or wires .
The symptom is no power with a feeling of a stall
It's starts , it idles well but give it some gas and it bogs
and dies . air fuel ratio I don't trust .
my plan is spend $20 get a fuel pump and filter
and go from there . I checked plugs Zero oil issues
the plugs seemed to have chalkiness with a whitish hue
Very dry like Bone dry
Can or do these lean burn systems when old - just mess up ?
Author:  wjajr [ Mon Aug 14, 2017 6:11 am ]
Before purchasing a new fuel pump, test it by disconnecting fuel line at carb and pump some fuel into a can.
Before the pump test:
Often when engine stumbles off idle under acceleration the cause is a lean condition until the main jets come on line, and caused by a failed accelerator pump.
Accelerator pump test:
Remove air cleaner, with engine off and choke held open look down into carb's barrel and rotate throttle open while looking for fuel squirting. Fuel delivered should be a robust squirt, and begin as soon as throttle moves. Weak, or late delivery after throttle opening is cause of lean condition requiring a carburetor rebuild.
Author:  Brian [ Mon Aug 14, 2017 6:49 am ]
It could be a carb issue. My 86 would have issues stalling out and bogging at times. It did get worse until the truck quit and I could not restart it. I took the carb apart and found particles from the charcoal canister plugging everything up. May not be your issue, just figured I'd tell you
Author:  Mr.6 [ Tue Aug 15, 2017 4:04 am ]
Thanks for the help
