It is currently Thu Nov 12, 2026 3:38 am
 Post subject: Coil Help??
PostPosted: Fri Aug 18, 2017 1:42 pm
I, for the second time in 5 years have accidentally left on my ignition switch and the MSD Blaster coil blows the top out of it all over the engine compartment. :cry: So I decided to get a non oil filled coil to try and eliminate the messes that I make. I ordered a "universal" E-core coil from Summit SUM-850615 and it looks really nice except for I did not see that it is specifically for CD ignition boxes. So I have been looking at what to get and the more I look the more confusing it is to me. I looked at the MSD Blaster SS Coils 8207, but it says you must run a ballast resistor and I don't want that. So help me out here please.
I am running a Mopar distributor with HEI and I want an E core design with mounting bracket to put it on my fender. Should not be that hard!
Thanks!
PS. If you want to school me on why the CD coil will not work I'd be glad to learn. I suppose it has to do with how it is triggered? Thanks!
PostPosted: Fri Aug 18, 2017 2:11 pm
I used an e-core coil bracket from a late 90's GM truck. It has the coil and a place for a heat sink with the HEI module attached. You will have to grind out the fin closest to the module and grind the locating tabs off the module so it will lay flat.
1976 Feather Duster /6 4sp
1984 W100 318 727 np241
1972 'Cuda 340 4sp
1985 D250 360 46RH
PostPosted: Fri Aug 18, 2017 2:18 pm
Okay, an ignition primer.
Kettering/Delco ignition: https://en.wikipedia.org/wiki/Delco_ignition_system
TLDR? With inductive ignition systems the ignition energy is stored in the coil's magnetic field and which then induces the high voltage in the secondary winding.
Capacitor discharge ignition: https://en.wikipedia.org/wiki/Capacitor ... e_ignition
The capacitor stores the ignition energy. The capacitor is charged to a moderately high voltage and discharged through the ignition coil which acts as a transformer to further raise the voltage.
This doesn't meant that a CD coil won't work in an inductive application, but it is likely not optimized for such. I would go get an original Ford TFI or GM HEI coil and bracket for use with the HEI module.
PostPosted: Fri Aug 18, 2017 3:14 pm
Thanks Josh! That helped!
I also found an Ignition basics article by Jeff Smith of "Chevy High Performance" That explained a lot of things too!
I have the Ford coil coming!
Let's see! A ford coil, triggered by a GM HEI and a Mopar Distributor! I think I have all the bases covered! :lol: :lol:
Rick
