It is currently Tue Nov 10, 2026 12:36 am
PostPosted: Mon Aug 14, 2017 2:54 pm
Car Model: 1973 Dodge Dart 4-Door Custom Sedan
Hey:
Does anyone know the location of the dash gauge voltage regulator for the fuel indicator?
Thanks
Shawn
PostPosted: Mon Aug 14, 2017 3:16 pm
On the back of the instrument cluster circuit board. for ease of access, you will have to drop your steering column and then pull the cluster to access it.
PostPosted: Mon Aug 14, 2017 4:09 pm
Maybe/not. What year and model is the vehicle in question?
 Post subject: It's...
PostPosted: Mon Aug 14, 2017 4:23 pm
1973 Dodge Dart... The IVR is right up against the column and pedal support bracket... if he has large hands, it's easier to pull the instrument panel to get it out... given he has had some issue with the gauges... he should look to see if the copper circuit traces on the board are still intact and not rusted/broken.
PostPosted: Tue Aug 15, 2017 3:36 am
Thanks guys, I'll give her a whirl...
Shawn
PostPosted: Thu Aug 17, 2017 9:47 pm
and a box of Bandaids.
PostPosted: Fri Aug 18, 2017 3:27 am
I can imagine!
