carb question
https://slantsix.org/forum/viewtopic.php?t=6153
Author:  sixty4dartgt [ Mon Jun 30, 2003 10:03 pm ]
Post subject:  carb question
What are the advantages/disadvantages of running a 2 bbl instead of a 4 bbl, if both have the same cfm (e.g. holley 2300 vs. edelbrock 500)?
Author:  Slant Cecil [ Mon Jun 30, 2003 10:33 pm ]
CFM constants have to be established before you compare 2 vs 4 barrels. They are rated at a different pressure, so the 2 barrel needs to be estimated at the same pressure 4 barrels are rated. The 500 CFM 2 barrel is easy to estimate. It is half of a 750 DP 4 barrel Holley, same venturii and throttle bore. So it flows 375 when at the same pressure as a 4 barrel. This makes the 500 Eldebrock a much larger carb. But the E 500 is a better street carb because of the vaccum secondaries.
I prefer Holleys only because I have plenty of parts for them and I am way more familiar with them. I like the 350 and 500 2300 and the 390 4150 Holleys for /6s.
I was told the difference between the 500 and 600 Eldebrocks were the 500 had a more restrictive booster, that both used the same throttle and venturii size. Anyone know the truth to this?
Cecil
Author:  Reed [ Mon Jun 30, 2003 11:47 pm ]
The edelbrock/carter afb carb is not a vacuum secondary carb. The Holley s a vacuum secondary carb. The Edelbrock is a mechanical secondary carb with the vacuum sensitive "airvalve" over the secondaries. I have farted around to no end trying to get Holley carbs tuned right, and wile I have no doubt that someone with the proper skill and patience can tune one, I have never gotten a Holley four barrel to perform adequately. The Holley 1920 is a nice simple carb and a good one, but it is just a one barrel. I am anxious to try the Holley 2305 staged two barrel on my slant when i get it running, but the only four barrel carb i would run on a slant would be an edelbrock or carter AFB, simply for ease of maintenance and operation. Plus the original hyper-pak was topped by an AFb and you can get the factory metering specs for a ballpark figure to start from.
Reed
Author:  DusterIdiot [ Mon Jun 30, 2003 11:55 pm ]
Post subject:  Errr...reed 4150 vs. 4160
Reed,
Holley has two sets of 4 barrel carbs excluding the "chevy" 4360, and the 4165/4175 spreadbore series...(we won't get into the 4500 Dominator either...)
The 4150/ 4160's can be either vacuum secondary carbs or mechanical secondary carbs, and you can customize them for whatever you need...I have one of each in my 'spares' pile...most guys will grab the Vacuum carbs, because they don't have to tech 'n tune the linkage to get the plates to drop open correctly....
You can get the 390 in either version...you can also get the 2300 in a monster 625 cfm version too.... :)
Been looking at Holley's too much...need to play with something else....
Author:  sixty4dartgt [ Tue Jul 01, 2003 5:25 pm ]
Thanks for the info but, it still doesn't tell me about the difference between running a 2 bbl vs. 4bbl. I'd like to know stuff like:
-gas milage
-power
-reliability
I have a stock '64 if that makes any difference. Thanks :lol:
