Plug question
https://slantsix.org/forum/viewtopic.php?t=61534
Page 1 of 1
Author:  downsr [ Wed Aug 23, 2017 6:27 am ]
Post subject:  Plug question
What plug do i need for 73 slant six and what is total timing on a slant six.Also
what would resistance coil would i use with a orange ecu and ballast resistor.Someone has converted it from points to electronic want to make sure they changed coil if needed.Looks like original coil.Thanks
Author:  SlantSixDan [ Wed Aug 23, 2017 9:21 am ]
The answer to your question about timing over here is the same as it was over there. Spark plugs: use NGK № ZFR5N (stock № 3459), with the metal ring washers removed before you install them.
Author:  downsr [ Fri Aug 25, 2017 3:01 am ]
Post subject:  plugs
The engine had n14y champions in it when i got it.I found a old chiltons book and it says to use n14y plugs .I bought a set of the ngk plugs you suggested and they are are longer than the n14y plugs.Will this be a problem if i put them in.Thanks for your reply
Author:  DusterIdiot [ Fri Aug 25, 2017 5:36 am ]
Post subject:  Nope....
Only if the slant had been milled for 10:1 compression or more... on a stock motor they fit fine.
