Phase 2, Holley carbs, initial jetting for the HP?
https://slantsix.org/forum/viewtopic.php?t=6160
Author:  DusterIdiot [ Tue Jul 01, 2003 5:33 pm ]
Post subject:  Phase 2, Holley carbs, initial jetting for the HP?
O.K. half a can later I've torn down every Holley 2300,4175,4150, and 4160 I have, and am going to grab 2 more 4160's tomorrow from a buddy.
questons to be asked about putting the Holley on the HP intake for street, Doc 's initial post indicated a 10.5 power valve, and a longer stronger pump shot...so far out of my 'autopsy' report...most of my power valves are 2 stage (one's rated at 10.5 and 5.5)...the others are straight 6.5's...
all the nozzles for the pump shot are 25's my biggest cam is an orange 466 (19/24.5 cc per 10 shots)....
most of my jets are 'close limit' jets from 512's to 612's, I have some 62's and a 71 and 76...
For the vacuum secondary 600 cfm carb to go on the Hp initially if I put the 10.5/5.5 power valve in, get a better/bigger pump cam (maybe a green or a pink one?) and leave the "shooter" alone...what would be a good number for initial jetting, should I throw the 562's in first (.055") and adjust from there?
The two 600's I have were set up for a 1966 383-4v and 'economy'...so I'm thinking they might be a bit rich and the pump shot isn't even close...
Tomorrow I'm going to grab two 1850-3's from a friend (600cfm vac.sec.) and see what they have in them, then get a rebuild kit...maybe I should rebuild those two carbs, and have one to start with, and one to 'adjust' off the engine, that way I can swap them and make 'changes' a bit easier?
anyhow, the holley is a nice 'modular' carb to work with, everything is easy to get to once the bowls come off....
thanks for any initial advice... :wink:
As a side note, the little 390 cfm 0-8007 I got from another member last year on .com was run on a slant (shorty manifold I'm sure), had a 6.5 PV and 512 jets (.050")...should I try to run this or would it be too lean with them long runners?
Author:  '74 Sport [ Wed Jul 02, 2003 7:30 am ]
O.K. half a can later I've torn down every Holley...
Only half a can? I figured you would have been through at least a six pack by the time you tore down that many carbs! :shock:
Ohhhhhh, you meant gasket solvent, didn't you? :wink:
Jerry
Author:  DusterIdiot [ Wed Jul 02, 2003 7:51 am ]
Post subject:  Yes, the strong stuff....
almost went there too....those gaskets are like tar on both sides of a peice of cardboard....
Any how, any holley guys have a 'good' guess as to where to start?
Author:  Dart270 [ Wed Jul 09, 2003 10:10 am ]
I think I used the green pump cam on my 600 with like 60-62 primary jets, stock squirters, and an 8.5 power valve (little bigger cam than yours). That should get you fairly close. I never messed with squirters, so that's another thing to try. The Slant will need a fairly big pump shot on a 600 for good throttle response.
I also remember jetting down thinking it was too rich when it was actually getting leaner, and I jetted up above the stock 600 jets for best performance. I advise getting a quick change secondary spring kit too.
Have fun!
Author:  DusterIdiot [ Wed Jul 09, 2003 10:28 am ]
Post subject:  Thanks Lou!!!
I have three candidates torn down right now, a 390 cfm holley (going to try it initially, because I know it ran on a shorty intake), and two 600 cfm holley's (one has a manual choke, both are vacuum secondaries).
The 600 cfm I'm looking more closely at is jetted with 64's and has a #6 plate (.070 main hole, .026 idle holes), and a pink pump cam with a '25' shooter (should make for a longer stronger shot like Doc said to play with).... all my power valves are 6.5's, I picked up a 10.5 yesterday and may go back for an 8.5 if needed...
Just trying to get my ducks lined up before I go tearing things down, I'm almost done with my rear manifold mod, the carb is next, and once the stack goes on, I'll have to measure up for a accelerator cable bracket.
Thanks again....
Author:  Slant Cecil [ Wed Jul 09, 2003 4:05 pm ]
Didiot, as with anything, there's no sure thing or absolute. But normally, the bigger the plenum, the weaker the signal to the carb. So expect to have to go up on jetting and especially pump shot from stock on even a universal performance (non-OEM) Holley carb (universal tend to be rich out of box). You may have to have a 50cc pump on the primaries and a hollow squirter screw if going over .040 in size. Just don't think it's strange to have to go bigger than usuall on fuel delivery.
Cecil
Author:  DusterIdiot [ Wed Jul 09, 2003 5:23 pm ]
Post subject:  Thanks Cecil!
I'll probably be picking your brain some. I've never had to rebuild a Holley Carb, I got the book, all the carbs are very 'modular' (can swap anything from any of the others....). The candidates are 'cooking' in the solvent tank as we speak. It's going to be a 'plug and play' then read the plugs.
Luckily one of the carbs came with a '31' shooter so if I have to go up on the nozzle from a '25',I'm good there, but may have to get a bigger spacer if I have to use a 50cc pump...there's only one cam bigger than the pink one...
Next up, I'll have to grab a spring kit...
We'll see what happens in the next couple of weeks, between un up coming class in Portland, and the potential for work, this project may get delayed...but you never know :wink:
Thanks for the help!
