| Oil Pan https://slantsix.org/forum/viewtopic.php?t=61602 |
| Author: | Lucentury [ Mon Nov 20, 2017 7:57 am ] |
| Post subject: | Oil Pan |
I believe I need a new oil pan for a 71 Duster with a 225. We had a new rear main seal block cast after the last one cracked after being previously tap and died. Now when the pan is installed it is leaking, but we cant find a new one or a published match for this engine/car. Has anyone else run into this issue? Is there any other pans that will work? |
| Author: | DusterIdiot [ Mon Nov 20, 2017 4:29 pm ] |
| Post subject: | Re: Oil Pan |
The more common oil pan can be gotten from any 1967-1976 A-Body (Dart, Dart Sport, Demon, Duster, Valiant) with a slant six. You also can use the oil pan from any F-body 1976-1980 Dodge Aspen or Plymouth Volare, but the oil drain plug will be in a different position (but is still usable in an A-body without issues). |
| Author: | Rick Covalt [ Mon Nov 20, 2017 4:40 pm ] |
Quote: We had a new rear main seal block cast after the last one cracked
Is the aluminum seal holder what is leaking or is the rear main seal leaking? Sorry I'm not sure what is leaking.Where are you located? |
