| EFI Turbo Update https://slantsix.org/forum/viewtopic.php?t=6161 |
| Author: | Bob D [ Tue Jul 01, 2003 6:50 pm ] |
| Post subject: | EFI Turbo Update |
This past weekend I took my second 250-mile trip with the EFI turbo. This one was a real test with the temperatures well into the nineties. So far I've got close to 1K miles on the turbo and it's running great. I've never driven a turbo car before and the thing that surprised me the most is the increase in power even under light load and before the boost goes positive. I guess I really notice it because I've driven this same car with and without a turbo. The difference is dramatic even under light load and at part throttle. This thing flies up hills! I'm running the boost at 7 pounds until I get a BTM hooked up. Then I'm planning on going to 10 pounds. Bob D |
| Author: | Jopapa [ Tue Jul 01, 2003 9:22 pm ] |
I expect a long, extensive, detailed article on the installation along the lines of your EFI article |
| Author: | Doctor Dodge [ Tue Jul 01, 2003 10:29 pm ] |
Thanks for the up-date Bob, sounds like things are working well. Any "bugs" or funny problems crop-up yet? DD |
| Author: | Bob D [ Wed Jul 02, 2003 12:46 pm ] |
Doug, The only "bug" I have is that the engine is a little difficult to start when warm. This is because I'm still using my batch fire ECM from a naturally aspirated 3.8L engine. So, with no sensor input during start-up the ECM "thinks" that the stock non-turbo 22lb/hr injectors are still being used. This results in too much fuel from the larger 28lb/hr injectors during start-up. During cruise the MAF (from a turbo 3.8L), and the oxygen sensor, keep the mixture right on. What surprised me a bit is that at WOT this ECM, along with the turbo MAF, keep up with the fuel requirements of the turbo. At least up to 7 pounds of boost. This really demonstrates the adaptability of the MAF system! I will eventually use a turbo ECM, but first I have to work out some timing issues to use the turbo "crank sensor" ECM with my distributor. I get around the warm start problem by starting the car in "flood clear" mode (pedal to the floor). When cold the engine starts beautifully. Bob D PS. Is something wrong with the site or is it just me? Everything is extremely slow. |
| Author: | Doc [ Wed Jul 02, 2003 1:30 pm ] |
Good info. Bob. As for the site, yes it is slow, one of the servers is down, Chuck is on it but it may take a few more days to get fixed. DD |
| Author: | Dart270 [ Wed Jul 09, 2003 10:13 am ] |
Cool beans, Bob. I may be picking your brain about parts and such in the near future. The itch for boost is getting unbearable over here! Cheers, Lou |
| Author: | Bob D [ Wed Jul 09, 2003 8:01 pm ] |
Lou, Your g-machine with EFI and boost would be the coolest beans! Bob D |
