Hylomar Sealant?
https://slantsix.org/forum/viewtopic.php?t=6163
Page 1 of 1
Author:  drwheelie [ Tue Jul 01, 2003 11:15 pm ]
Post subject:  Hylomar Sealant?
Hi
I am just finishing up my super six conversion. I am learning a ton so far and am just working out the final bugs so I can crank the car up for the first time.
I followed the manifold install instruction on the site almost to the letter.
Part of that included using Hylomar gasket maker on the gasket. I noticed something pretty weird about the stuff. It doesnt seem to harden at all. I placed it around the ports on both the head and the manifolds and some gooped out a slight bit around a few of the flanges of the manifold. I came back 2 days later and it was still the same consistency as when I applied it.
I am assuming this is how it is supposed to be.
Anyone have any info about why?
Thanks
Dr. Wheelie
Author:  a different slant [ Tue Jul 08, 2003 12:39 am ]
Post subject:  about Hylomar...
Hi drwhellie... yes you are right, Hylomar is a bit weird, as it does not harden. I read about it over a year ago in a Mopar mag. and have used it a fair amount, in fact just yesterday on an intake gasket for a Phord (I'm a mechanic/shop owner, just finished up 4 Phords in a row...) Suposedly it was developed by Rolls-Royce. ANyway it says on the tube it is a flange sealant, and in my experience it works well on flat surfaces/gaskets like around ports on our Slants. I have also found it to not work so well to seal water, as on a pitted/corroded thermostat housing. I would not use it as a substitute for a gasket, but as a "dressing goop" I have heard(but not tried) that it works on header gaskets. I just smear a thin layer on the metal surfaces that will join up, then "sandwich" the gasket in between. One thing I like about it is that it is easy to remove with some carb. cleaner or laquer thinner when you take something apart, unlike silicone, which can be a chore, and that It acts like it will stay put and resist most automotive fluids... it gives you better "control", you can just wipe it off anything where you don't want it, pretty cool stuff, I think! If I want something more "substantial", I use Permatex#2 in a tube,wich also can be removed by any good solvent but seems more resilient, though Iwould not put permatex #2 on an exhaust application. Anyway, hope this sheds some light.... happy Slanting!! Tracy Gallaway
Author:  drwheelie [ Tue Jul 08, 2003 6:27 am ]
Thanks
I did some net research on the stuff and found out more about it.
When I was working on my / I still used rtv for the water neck so I made a good choice there.
I used some hylomar to help keep my valve cover gasket in place so I could get my valve cover back on without any troubles.
I think I will continue to find new uses for this cool stuff
-DW
Author:  slantzilla [ Tue Jul 08, 2003 3:44 pm ]
We use Hylomar on head gaskets for Continetal engines at work. When you spread it out into a thin layer it will get very tacky.
Author:  Volaredon [ Tue Jul 08, 2003 10:17 pm ]
Post subject:  Gaskets
As an auto mechanic by trade, I have always been told that if you are using a cut gasket, the only purpose a sealant serves is to hold the gasket in place til you get the bolts in and everything lined up. I HATE finding T-stat housings so loaded with RTV that you would wonder how any water gets thru? :evil: RTV is only good at seams, like a 4 piece V8 manifold in the corners, or by itself without a cut gasket. And then, only if allowed to START setting up before the part is installed. On things like a T-stat, especially ones like our Slants that mount vertical, I set the stat in the recess in the neck, then apply the gasket with Weatherstrip adhesive, (Yeah, good ol'gorrilla snot!) on the neck side only, let it set up and then put the stat and neck on together without the worry of the stat falling out of the recess as it is turned vertical. As long as you don't use too much of your favorite sealer as to clog up something that ain't supposed to be,
use whatever works best for you. Just BE SURE that the surfaces are absolutely clean, or nothing will seal.
Author:  Charrlie_S [ Wed Jul 09, 2003 6:59 am ]
On my turbo engine , the block is "O" ringed, around the bores. I am using a solid copper head gasket, from Cox Bros. They told me, to use Hylomar, on the head gasket, to seal the water and oil passages. So far so good, I have no seepage.
Author:  Craig [ Wed Jul 09, 2003 8:17 pm ]
Post subject:  Where get this Hylomer stuff?
Where does one get this Hylomer stuff?
Author:  drwheelie [ Wed Jul 09, 2003 10:35 pm ]
I got it at NAPA with all the other gasket junk
Mine was made by Permatex so it should be readily avialable everywhere
-DW
Author:  jack [ Thu Jul 10, 2003 7:26 pm ]
I used this stuff on my manifolds gasket as suggested in a post here. It lasted exactly 1 month and then started leaking. Couldn't take the high heat of exhaust and I had too much space to fill I guess.
Author:  drwheelie [ Thu Jul 10, 2003 8:40 pm ]
Do you mean you used it on the gasket where the 2 manifolds join together at the heat box or where the head meets the block?
I would think it is not the best choice for the intermanifold gasket since you need some volume of gook to get a good seal between them especially if the mating surfaces are pitted
-DW
Author:  jack [ Fri Jul 11, 2003 8:50 am ]
I used it where the head meets the block. I used copper colored goop between manifolds. BOTH failed.
I now have a lot of experience at this task and am convinced of the following:
Use NO sealer either manifolds to block or manifold to manifold. Take the manifolds apart if they were leaking manifold to manifold. Manually inspect them to make sure the mating surfaces are not pitted. Use a new manifold to manifold gasket with NO sealer. Take the bolted together manifold set to a machine shop and have the manifolds to head surface made flat - just pay the money it will be worth it. Use NO sealer manifolds to head and use a torque wrench and the correct fasteners and tightening sequence to attach manifolds to head.
This is the only procedure that worked for me and this was after 4 failed attempts which included placing the manifolds on a very flat surface for visual inspection. Use a machine shop if they were leaking, believe me.
Author:  drwheelie [ Fri Jul 11, 2003 9:33 am ]
Well now youve gone and made me paranoid!
I inspected all surfaces and found them to be in find shape.
The flanges on both manifolds had been cleaned and it looks like they had been worked a bit to make them nice and flat.
I test fit everything 2 times and used a feeler gauge to check clearances.
I used the reccomened napa gasket and all the right hardware in the right places. I hylomared around each port on both sides of the gasket.
On the interman gaskets I flat filed them and removed all pitting, then I gooped hi temp rtv just like the instructions said.
I used a good torque wrench to install all of the bolts to spec and ran a tap on all the threads of the head studs to clean them off. I used new nuts and cleaned and painted all of the washers.
So far I have put about 100 miles on the thing in the high heat of new orleans heavy traffic and things seem fine.
Other listers, should I be paranoid about leak problems?
What are your experiences?
-DW
Author:  killin5 [ Fri Jul 11, 2003 10:23 am ]
DW,
You should be ok. I did the same thing about 2 years ago and have not had problems.
John
DW,
John
