| World's Heaviest Head https://slantsix.org/forum/viewtopic.php?t=61636 |
| Author: | hyper_pak [ Sat Nov 25, 2017 6:14 pm ] |
| Post subject: | World's Heaviest Head |
Just finished putting together the head for my Lancer. I am using the 75-77 head, 3698447, and it must weigh a ton! Next time I build one of these heads I am going to cut the cast iron out from the push rod side and see how much I can save. |
| Author: | Badvert65 [ Sun Nov 26, 2017 7:20 am ] |
| Post subject: | Re: Worlds Heavest Head |
I think those heads are about 10 lbs heavier than the earlier heads. I would be curious to see how much you could lighten the head, but I don't think it would be near 10 lbs. I am curious, what is the lightest factory slant head and what is the lightest iron head anyone has built? |
| Author: | DusterIdiot [ Sun Nov 26, 2017 11:43 am ] |
LOL... yeah compared to the 1974 and earlier drool tube head or the 1981-1987 hydro motor head, it's a monster... but not as heavy as the non-exhaust air port injection head that has the lack of air ports and passages... It will take a while to carve out that section, I've run a burr in there to help with oiling and relieve the pushrod holes a bit when running 3/8" pushrods...there's a lot of meat. I don't think I've ever figured out what's worse in weight and lower back soreness... laying an early to mid-60's forged crank or a 1975-1980 head.... |
| Author: | 62 alum [ Sun Nov 26, 2017 3:43 pm ] |
I am getting ready to send a 220635-2 head off my 1962 to the machine shop for work. Bare and clean 66/67lbs. When I get it together again I will weight it to get a total. |
| Author: | tophat [ Sun Nov 26, 2017 3:52 pm ] |
The in line 6 head of a 60's to 80's Jag, now there is a heavy beast. |
| Author: | hyper_pak [ Sun Nov 26, 2017 5:32 pm ] |
I will weigh it tomorrow, I am guessing 85 with valves. It will take a while to get that much cast iron off for sure. I wonder if this head would be good for a turbo and for gasket sealing? |
| Author: | lgu32 [ Tue Nov 28, 2017 12:17 pm ] |
| Post subject: | Re: World's Heaviest Head |
Nice. I was thinking I am coming old and weak. 35 years ago it was easy to install mid-60's head alone. Now with small plug head I need a crane or assistant. But it was only because they have add material for late heads. |
| Author: | 62 alum [ Fri Dec 15, 2017 3:00 pm ] |
Just got my head put back together after the machine work. Complete from plugs to stat housing. 74/75 lbs. |
| Author: | wjajr [ Sat Dec 16, 2017 11:15 am ] |
DI: Quote: but not as heavy as the non-exhaust air port injection head that has the lack of air ports and passages
That's the one riding atop my engine, yup, heavy, heavy, heavy.
| Author: | hyper_pak [ Fri Dec 29, 2017 5:40 pm ] |
Put it on the scale, 80.8 with valves and springs. After .100 cut. No t-stat or rockers. Dang. |
| Author: | Dart270 [ Fri Dec 29, 2017 7:48 pm ] |
Must be a record! Lots of metal to hog out to make flow... Mike J said he liked those late 70s heads best for that reason - more material to remove. Lou |
| Author: | DusterIdiot [ Fri Dec 29, 2017 7:53 pm ] |
Quote: Mike J said he liked those late 70s heads best for that reason - more material to remove.
Yeah, it's not a weight saver, and the pushrod holes are a bit small... but the "Fatpak" head I hogged the crap out of to port match that intake...I hadn't hit water and i know a drool tube head wouldn't take that kind of abuse.... |
