| Where to drill through firewall? A/C installation https://slantsix.org/forum/viewtopic.php?t=61644 |
| Author: | Schmoe [ Mon Nov 27, 2017 7:39 am ] |
| Post subject: | Where to drill through firewall? A/C installation |
Hello. I am installing A/C on my 65 Dart GT. I am looking for recommendations and hopefully pictures as to where I should drill through the firewall. I bought the aftermarket kit that has the box that mounts under the center of the dash. Thank you for your time. |
| Author: | SlantSixDan [ Mon Nov 27, 2017 9:48 am ] |
| Post subject: | Re: Where to drill through firewall? A/C installation |
What kind of A/C setup are you putting in? |
| Author: | Schmoe [ Mon Nov 27, 2017 10:17 am ] |
Hello Dan. I purchased the Nostalgic Air Saden Kit. I'm using their supplied bracket. |
| Author: | Schmoe [ Wed Jan 17, 2018 12:30 pm ] |
Hello. Just checking to see if anyone has pictures or best location as to where to punch through the firewall for A/C line installation. |
| Author: | 64 Convert [ Wed Jan 17, 2018 4:42 pm ] |
Quote: Hello. Just checking to see if anyone has pictures or best location as to where to punch through the firewall for A/C line installation.
My installation uses Vintage Air parts and behind the dash location, but maybe this article about my '64 Valiant installation will help a little.http://www.slantsix.org/articles/vintag ... ge_Air.htm |
| Author: | Schmoe [ Fri Jan 19, 2018 12:26 pm ] |
Thank you. Yes, this is helpful. I am keeping the factory heater core, so mine will be a bit different. Perhaps I cut through in the location where this person has re-routed the heater hoses. I have a Clifford valve cover and the engine is out getting built, so it seems like I can't go any further until I get the engine in. The last thing I want to do is drill holes and then find that the valve cover is in the way of my line fittings. |
| Author: | Charrlie_S [ Fri Jan 19, 2018 5:59 pm ] |
Here is a link to an install I did some years ago http://www.forabodiesonly.com/mopar/thr ... tem.51820/ |
| Author: | Schmoe [ Wed Jan 31, 2018 12:15 pm ] |
Thank you very much, Charlie. This is extremely helpful. I will be following this setup when I install mine. |
