63 Dart disc brake conversion
https://slantsix.org/forum/viewtopic.php?t=6165
Page 1 of 1
Author:  storm637 [ Wed Jul 02, 2003 10:15 am ]
Post subject:  63 Dart disc brake conversion
Has anyone done this before? What kind of donor car can I get the parts from and what parts do I need?
Author:  jonclass [ Sat Jul 05, 2003 12:04 am ]
There's a kit available from Wilwood that's supposed to be fairly light-weight, but I don't know how much it costs. I'm doing a swap to discs for my 64 valiant right now using all of the suspension and brake bits from a 76 duster. Rather than restating everything I'm doing, you could take a look at what Rob (?) has to say on the subject at http://users.rcn.com/alokaeng/Techhelp. ... and%20Swap He's got a decent write-up of what you'll need.
-Jon
Author:  Matt Cramer [ Sun Jul 06, 2003 2:25 pm ]
Post subject:  Just like a later Dart.
There's several options for this. There's aftermarket kits. There's several different ways of adapting junkyard discs - either the '72-earlier conversion (needs the ball joints and everything in between from a disc car) or the '73-up conversion (same, but also needs the upper control arms). With the '73-up hardware, you will have the large bolt pattern, which allows a wider selection of wheels but means you'll have to swap the rear bolt pattern too. There are a few mix-and-match options using taller F/M/J body spindles or the late '70s B-body 11.75" discs and caliper brackets on post-'73 spindles, too.
Author:  74.swinger [ Thu Jul 24, 2003 7:45 pm ]
This may be of interest to someone
http://www.bigblockdart.com/cgi-bigbloc ... 1058137915
Author:  mighty mouse 63 [ Fri Jul 25, 2003 12:02 pm ]
Post subject:  One more reason to convert
Think i'll piggyback on this post as iv'e had it with the stock 63 ball joints and tie rods,tired of replacing them every two years and a conversion would be a relief. Guess you can tell what I did on my days off. ...thanks for the information guys...Dave
Author:  killin5 [ Fri Jul 25, 2003 2:13 pm ]
This is an excellent book that pulls together the junkyard approach to doing a disk type conversion.
Performance Handling for Classic Mopars
by Tom Condran
$30.00 - 162 pages
Faster Forge and Press
P.O. Box 282612
San Francisco, CA 94128-2612
http://www.moparpages.com/suspension_book/
Author:  Dart270 [ Fri Jul 25, 2003 2:59 pm ]
You should also check out a good brake article ("Disc-o tech"??) at www.moparaction.com
