| slant belts https://slantsix.org/forum/viewtopic.php?t=61712 |
| Author: | joeh [ Mon Dec 11, 2017 5:23 pm ] |
| Post subject: | slant belts |
How do the belts run for alternator, air and power steering? |
| Author: | Charrlie_S [ Mon Dec 11, 2017 6:28 pm ] |
| Post subject: | Re: slant belts |
Clockwise from looking from the front. Seriously, closest to the timing cover, is crank, A/C, and water pump next out is crank, alternator, and water pump front is crank, and power steering. |
| Author: | joeh [ Mon Dec 11, 2017 7:03 pm ] |
A guy gave me a motor with alternator air and power steering with no belts on it and only 2 pulleys on the crank How would that work? |
| Author: | Reed [ Mon Dec 11, 2017 7:27 pm ] |
Is the second pulley on the crank in front of or behind the harmonic balancer? |
| Author: | joeh [ Mon Dec 11, 2017 7:42 pm ] |
I think it is behind and their are 2 pulleys on the fan |
| Author: | Pierre [ Mon Dec 11, 2017 9:46 pm ] |
Then it's missing the front pulley. The front and rear pulley bolt on to the crank vibration dampener with 3 bolts each. If you look closely at the crank pulley you should see 6 bolt holes - 3 of yours have bolts in, the other 3 don't |
| Author: | Charrlie_S [ Tue Dec 12, 2017 4:54 am ] |
That's correct. You got lucky that it's the front crank pulley you're missing. Easy to install, and fairly easy to find. Someone on here should be able to help you with one. |
