It is currently Thu Jan 01, 2026 4:11 am
PostPosted: Sun Feb 18, 2018 8:43 am
Car Model: 1974 W100; 72 Dart
Anyone have installed pics of Cifford header in an early A with a 3 speed. Mostly interested in how people are routing the pipes around the clutch mechanism and shifter linkages.
Not sure I will use the headers on this project if it is a huge ordeal.
sb
PostPosted: Sun Feb 18, 2018 2:16 pm
Closest I have is pictures of a '66 Dart with a 4-speed. The clutch linkage is close, but fits. Can't help with 3-seed shift rods.
PostPosted: Sun Feb 18, 2018 6:36 pm
Will take whatever you are willing to share. PM sent.
sb
PostPosted: Mon Feb 19, 2018 3:24 am
The old Clifford long tubes did fit ok with a 4 speed. Only 3 tubes went back down through by the clutch linkage and the other 3 went down through at the K frame up front.
